| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Can too much oil in the engine show a code ?
__________________
97 4Runner SR5 2.7L 265/70/16 Toyos K&N filter NGK spark plug wires Bosch Platinum plugs So far 24 mpg for 30 000 km |
#2 (permalink) |
Can't say much without knowing the code. Get it pulled by a nearby shop or by a friend with a OBDII scanner, then post it up here. Once you have the code, you can search it here and find the information you need. There is a posting on the site somewhere that lists all the codes and the associated error messages. Good luck.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold |
#3 (permalink) |
Thanks I`m looking for someone with the code reader .They are kind of xpensive to buy .
__________________
#4 (permalink) |
check out your local advanced auto or simlar store.. they have the free to use one
__________________
Pat 1999 4Runner SR5 V6 4WD - Brush Guard, lift, Duelers, roof rack, acouple lights ~You will always be my little boy~ Hobbes (11/28/05) Future mods- more lift, tire gate, sliders, better lights, engine upgrades. |
| Tags |
| 07, 2002, activate, avoid, camry, change, check, engine, excess, kn, light, liter, oil, prius, transmission |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Check engine light on, any way to get it to show code? | sworxx | 93-98 T100s | 0 | 01-01-2007 09:37 AM |
| Engine show some eating metal | Guardian_Saint | 86-95 Trucks & 4Runners | 0 | 09-18-2006 11:10 PM |
| Engine Knocking and engine code 13 help please | garthed | Maintenance & Repair Archives | 3 | 08-11-2005 10:37 AM |
| Engine Knocking and engine code 13 help please | garthed | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 08-09-2005 08:03 PM |
| Engine code help!!!! | mattk | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 03-09-2004 06:36 PM |
