Burnt ATF Fluid? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-06-2005, 10:51 PM   #1 (permalink)
vegaskurt's Avatar
Burnt ATF Fluid?
Need a little help, 160k on my 97 4runner. Previous owner thinks he had the fluid change. "thinks".
Any ways, I dont have the best nose so Im not sure for what to smell for. Here is a paper towel I wiped the dipstick off on to. Am I ok or is it cooked? The darkness might be from the dip stick...
First pick is from the dip stick, second pic is the same paper towell an hour later.
vegaskurt is offline
Old 11-06-2005, 10:59 PM   #2 (permalink)
gapguy's Avatar
Send a message via AIM to gapguy
That fluid looks pretty clean to me....
__________________
2008 Mini Cooper
gapguy is offline
Old 11-06-2005, 10:59 PM   #3 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
looks ok... but looks can be deceiving.... might want to go get it flushed jsut to be on the safe side
jimbo74 is offline
Old 11-06-2005, 11:06 PM   #4 (permalink)
vegaskurt's Avatar
Yeah, I want to flush it. Probably mobil one or red line if I can get the cash. Just wanted to make sure it wasnt burnt.
Old 11-07-2005, 01:36 AM   #5 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Nah, that's not burnt... I wish mine looked like that!
Remember, that when you get it "flushed" the right thing is that you should also be paying for about 10-12 quarts of tranny fluid. The point being that a real flush is to generally replace everything in the tranny... That's a lot different than getting it "drained and replaced".
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 11-07-2005, 09:59 AM   #6 (permalink)
vegaskurt's Avatar
I thought it was 16 quarts of fluid to flush the 12 in the tranny?
Old 11-07-2005, 10:29 AM   #7 (permalink)
Sponsoring Member
midiwall's Avatar
Ahh.. good point. Yes, you're right, I was thinking about tranny capacity, not the amount of fluid required to do the physical flush.
__________________
~ Mark
midiwall is offline
Old 11-08-2005, 03:07 AM   #8 (permalink)
KZN185W's Avatar
looks clean and unburnt... as long as it does not have the white flakes, then the atf is not burnt.
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Battery l LT285/75R16 l Recaro Seats
Drive Your Dreams
KZN185W is offline
Old 11-08-2005, 10:13 AM   #9 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Put it on a piece of white paper next to a dab of fresh fluid for reference.
The fluid does look a bit brown to me but it is tough to tell in your pic.
I would defintely change the fluid one way or another.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Tags
4runner, 98, atf, auto, automatic, brown, burned, burnt, change, fluid, smell, smells, stick, toyota, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Mixing ATF Fluid with Toyota Lazybummm 95.5-2004 Tacomas & 96-2002 4Runners 2 07-02-2007 10:42 PM
Mixing ATF Fluid? chadbobb General Vehicle Related Topics (Non Year Related) 7 09-18-2006 07:22 PM
What is Burnt smelling Trans fluid? cancow 95.5-2004 Tacomas & 96-2002 4Runners 3 02-22-2006 05:46 AM
ATF fluid change concerns vegaskurt 95.5-2004 Tacomas & 96-2002 4Runners 5 11-02-2005 01:45 PM
2009 InternetBrands, Inc.
