Sign in using an external account
| Maintenance & Repair Archives Note: This section will be merged in with the other tech areas soon, and is now closed |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | |||||
Personal
Sales Rating: (0)
Brakes pulling to one side
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up /f199/ukmyers-1994-4runner-build-up-thread-104000/ Need Toyota Parts? www.davezoffroadperformance.com Quote:
#2 (permalink) |
Personal
Sales Rating: (0)
It could be a bad brake hose or a caliper sticking.
#3 (permalink) | |
Personal
Sales Rating: (0)
Re: Brakes pulling to one side
Quote:
__________________
Toyota Master Diagnostic Technician "MDT" 2010 Ram 2500 Cummins 6 spd 2003 Toyota Highlander 4WD 2006 Toyota Tercel 2DR 2007 KTM 105SX 2007 KTM 85SX 19/16 2006 KTM 300XC-W 2002 Yamaha TTR 125L 2002 Kawasaki KLR650 2002 Suzuki Eiger 400 4WD Licensed "Amateur Extra" Class Ham Radio Operator |
#4 (permalink) |
Personal
Sales Rating: (0)
Joey , it is real easy to get at the front pads all you need to do is whip the wheel off and the pads are in a swinging frame that is held in place by a small pin at the bottom, after removing the locking pin lift the frame up and give it all a good clean stick a new set of pads in and see how it goes.
best of luck mark
__________________
too much month left at the end of the money 1990 Hilux Surf 2.4 turbo diesel Japanese import (2nd gen 4runner) |
#5 (permalink) | |
Personal
Sales Rating: (0)
[OP]
UPDATE: Found out it was much simplier than I thought. Turns out last time I was wheeling I had aired down and somehow or another got some dirt lodged inside the rim. It had caused a very slow leak. When I went to go home from work the other day I thought hmm that tire looks low so I checked the pressure and it was down to 12 PSI!! No wonder it was pulling under braking. I can't believe it wasn't pulling worse and highway speeds. Anyways after a trip down to the tire shop to have the rim scraped clean and the tire remounted it's all back to normal now
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000 Need Toyota Parts? www.davezoffroadperformance.com Quote:
| Tags |
| 1st, 4runner, brake, brakes, changing, drivers, front, gen, left, piston, pull, pulling, pulls, side, stuck, truck, tundra |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Pulling when applying brakes | anniesball | 86-95 Trucks & 4Runners | 7 | 05-09-2006 09:26 PM |
| Brakes Pulling To Passenger Side, 2nd gen 4runner | jsnby | 86-95 Trucks & 4Runners | 5 | 12-20-2005 07:23 AM |
| Replace drivers side injector w/out pulling plenum? | dusty98 | Maintenance & Repair Archives | 1 | 04-21-2005 08:18 PM |
| What causes your brakes to pull to one side? | UKMyers | Maintenance & Repair Archives | 8 | 06-19-2003 12:10 PM |
| Brakes seem weak and are pulling | UKMyers | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-27-2002 11:49 PM |
