bottom end work maybe - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-09-2005, 03:14 PM   #1 (permalink)
abalagtas's Avatar
Send a message via Yahoo to abalagtas
So my 4Runners starts leaking coolant from some where behind the engine. I was praying it was a busted heater line, but I'm pretty sure it's a BHG. About 3 wks ago, the pwr wire on my fan wiggle loose, so the fan wasn't working. I didn't notice until I was heading up a small hill and the temp started rising. I stopped immediatel and found the problem. The guage rose but never in the red. I thought I might have prevented any damage.
I've got it a ProTrucks here in San Diego and they are doing some test before they give me the bad news. They've told me that a couple of cylinders have low compression which I knew.
I can't afford a full rebuild at this time, so I'm not sure what to do if the compression rings are really shot (I've known they (low comp cylinders) might have been suspect for a year)
The HG alone will be about $1100 w/valve job $1800. I don't know what the bottem-end will cost.
What can I get away with not doing to buy me some time?
We talked before hand about the 3.4 swap and they have done a few, but they are having problems passing Cali Smog.
__________________
Semper Fi,
Alfred
'91 4Runner SR5 4wd 3.0 V6
'10 Scion Xb
abalagtas is offline
Old 11-09-2005, 03:41 PM   #2 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
compression test is rings (i think) a leakdown test is Head Gasket (i think)
Although not unheard of usually if your HG is leaking your going to be smoking like you have a James bond smoke screen system.
find an engine that someone pulled out put gaskets in it for $300 and bolt it in.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 11-09-2005, 06:30 PM   #3 (permalink)
kyle_22r's Avatar
usually if the problem is your rings all the cylinders will be low. my money is on it most likely being a head gasket, though you'll have to pull the head anyway to re-ring the engine, in which case you're better off just rebuilding it.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 11-09-2005, 11:05 PM   #4 (permalink)
abalagtas's Avatar
couldn't the HG leak to the outside and not cause the 007 affect? I didn't find any coolent in the oil and the engine wasn't running bad, but a lot of coolant was leaking.
How much is it to rebuild the bottom end?
__________________
Semper Fi,
Alfred
'10 Scion Xb
Old 11-10-2005, 08:04 PM   #5 (permalink)
kyle_22r's Avatar
a head gasket can definitely leak outside the engine, i've had one seep coolant off the side of the block.
http://www.engnbldr.com/toyota3.0V-6.htm - master rebuild kit for a 3.0, $368. everything you need to rebuild the bottom end, as well as the rest of the engine.
__________________
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 11-19-2005, 01:24 AM   #6 (permalink)
abalagtas's Avatar
update:
It ended up being a BHG and burnt valves (#5 and #6). Also, the heads had hairline cracks. Not sure which problem started first, but in the end it cost me $2,300.
__________________
Semper Fi,
Alfred
'10 Scion Xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
This engine bottom end stuff is getting confusing..... vmax84 86-95 Trucks & 4Runners 20 04-24-2007 02:34 PM
What should I expect to pay for the machine shop to do my bottom end? vmax84 86-95 Trucks & 4Runners 8 01-22-2007 06:01 PM
Front end work RLJ3RD Maintenance & Repair Archives 7 08-04-2005 09:57 PM
Hosed bottom end? The Rusty Gear 95.5-2004 Tacomas & 96-2002 4Runners 2 08-17-2004 02:57 PM
Front End Work Nate 95.5-2004 Tacomas & 96-2002 4Runners 2 05-18-2003 07:38 PM
2009 InternetBrands, Inc.
