Back Window Motor HELP ASAP please :)
im right in the proccess of swaping motors on the back window becuase my new runners doesnt work. Do i just switch the black deal that says DENSO on it, or do i have to swap that whole assembly.. If so will the back window just fall if i take it out and break..
Not familiar with the rear window and Im not sure if this is gonna help or not but here it is: http://www.4crawler.com/4x4/CheapTri...arWindow.shtml Good Luck!
Well, you can change out the motor only if you want to, but it can be tricky. you don't want to mess up the gears for lose a spring or something.
If you change the whole thing, you have a better chance of everything going right. The rear window is held on by clamps. be sure to hold the window when you undo the clamps.
it's not too hard.
Good luck
Kent
it's not too hard.
Good luck
Kent
changing the motor is a cake walk. get into the tailgate (window can be up) 3 8mm bolts on the back of the motor that connects it to the regulator. loosen those, pop off the motor and put the new one in. the window should not move, mine did not anyways when i changed the motor. good luck with it
06-01-2021 01:51 PM
