| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
97 V6 4x4 4Runner Auto Tranny Jerks into Drive
#2 (permalink) |
We had a car that did that right before the tranny took a dump on us. took about 3 seconds for it to shift into drive, and it could take 30 sec. to a minute or longer before it would go into reverse.
__________________
DJ 1994 Pickup 22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around... Preping for SAS...... Originally Posted By Fustercluck "Proof that Gangus did not spontaneously generate....he has relatives." Originally Posted By Tacoclimber "My two year old better get a job, soon..." Reply Posted By Oly884 "I hear coal mining is a great career." Myspace |
#3 (permalink) |
First, check the AT fluid (with the engine running). Then, after you check it, smell the dipstick and let us know what it smells like.
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#4 (permalink) |
Reverse is working OK, I am planning on taking it to the dealer
to have them check it out. |
#5 (permalink) |
when was the last time you serviced the trans. (fluid and filter) i bought a older lexus ls 400 for 800 bucks because the tranny was slipping bearly catching. i serviced it twice and problem solved. filter kits are about 25 bucks for a lexus so i think yours shouldnt be more than that. that plus ATF is still cheaper than a 70 dollar daisgnostic at a dealer.
#6 (permalink) |
I can't believe you are taking it to the dealer before checking the fluid...
__________________
#7 (permalink) |
Thanks for your responses.
The truck is currently with my sister so I had her check the fluid, it is the correct level and with reddish/brown color. I did several drain/refills with at 40k miles about 4 years ago with conventional fluid and then did the final fill with Mobil 1 ATF. My sister is not handy with a wrench so, I am leaning towards having her get a BG Transmission flush and seeing if the problem goes away. Thanks again! |
#8 (permalink) | |
Quote:
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#9 (permalink) |
Rear Axle seal leak!
Update:
My sister took the 4runner to the dealership on Thursday. They looked at rear wheels and the brakes and told her everything looked fine on the rear wheels/brakes. And the problem could not be recreated since the truck was "warmed up". She left it overnight so they could look at it "cold". She got a call today and they are telling her that there is a leak from the rear axle seal and the brakes are sticking. She is going to get both rear axle seals replaced, and get new rear brakes. Hope this fixes the problem. Thanks for all your responses! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 97 4runner auto 3.4 4x4 --- $6500 | safado4 | The Classifieds GraveYard | 8 | 07-24-2007 10:14 AM |
| Auto tranny probslems 95 4runner V6 | cr500rider | 86-95 Trucks & 4Runners | 4 | 03-28-2007 04:36 PM |
| '96 4Runner V6 Auto Tranny/Transfer Case | 914runner | The Classifieds GraveYard | 3 | 01-22-2007 10:16 AM |
| 1992 V6 Auto 4x4 4Runner Tranny & Transfer Case | mtsumedi | The Classifieds GraveYard | 1 | 12-03-2006 06:59 PM |
| 1991 4Runner 4X4 Auto 3.0 V6: Should I buy it??? | bluesquirrel | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-25-2004 01:29 AM |
