82 Toyota 4x4 w/Tranny issues - what's the best solution? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-28-2005, 05:39 PM   #1 (permalink)
Hey all, got an 82 4x4, i've had it for about 6 years, had to replace the tranny at about 99,000 miles due to wierd squeaking/grinding sounds starting in 5th gear, then 3rd, then every gear but 4th...of course I just replaced the stereo and drove it to Mexico, and only replaced the tranny when it got so bad I figured it was gonna just blow up soon....anyways finally got it replaced with a rebuilt transmission and was good to go....
so 12,000 miles later, i've got the same squeeking/grinding sounds, (guess it's a bearing issue?) and want to fix em this time for good!
My question is , what's the best solution for this issue? A transmission from a different model year? Rebuild the one i've got with different gearing? (tires are 31x10.5)
thanks in advance for any help!!!
Brian
82Yoda4x4 is offline
Old 08-28-2005, 05:44 PM   #2 (permalink)
89macrunner's Avatar
your better off finding a newer tranny and using an adaptor from marlin crawler...
dont rebuild your current one because it could just keep on breaking, changing your gears in the tranny isnt needed..change the ones in the rear end
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles
Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008)
2006 Mazda3 GT
2000 TRD Tacoma..Bought back and crushed
1988 4Runner SR5 V6 5 speed..sold
89macrunner is offline
Old 08-28-2005, 05:45 PM   #3 (permalink)
EWAYota's Avatar
Send a message via AIM to EWAYota Send a message via MSN to EWAYota
did you replace the tranny the last time or have a shop do it?
__________________
DJ
1994 Pickup
22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around...
Preping for SAS......
Originally Posted By Fustercluck
"Proof that Gangus did not spontaneously generate....he has relatives."
Originally Posted By Tacoclimber
"My two year old better get a job, soon..."
Reply Posted By Oly884
"I hear coal mining is a great career."
Myspace
EWAYota is offline
Old 08-28-2005, 05:54 PM   #4 (permalink)
a shop did it - don't know anything about the source/quality of the rebuilt they put in.
__________________
82 Toyota 4x4 Shortbed, 114K original miles, 31x10.5 tires, all stock except for a Flowmaster 2 1/2" Catback muffler mod...
Old 08-28-2005, 06:00 PM   #5 (permalink)
kyle_22r's Avatar
the '79-83 trannies weren't known especially for their strength. '83 had the L52 which is the strongest.
marlin crawler can rebuild your tranny with bigger bearings and a gearset from a later model G54 transmission which is much stronger. you could also put in a later model transmission but they're about 4" longer and you'd have to relocate the crossmember, shifter holes, and resize the drivelines.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Tags
4x4, 82, 87, bearings, forums, g52, g54, rebuild, rebuilt, repair, toyota, trans, transission, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
89-95 Toyota 5spd 4x4 Tranny and case wooprdr The Classifieds GraveYard 6 05-20-2007 04:44 PM
99 4x4 Limited 4Runner - Tranny issues @ 94K? MarkAidan 95.5-2004 Tacomas & 96-2002 4Runners 10 02-13-2007 06:54 AM
I am thinking about getting a 82 Toyota pickup 4x4 1styota4X4 Pre 84 Trucks 14 01-02-2007 04:38 PM
a-arm rubbing issues - solution came in the mail today AznSky Offroad Tech 24 10-16-2005 11:18 AM
some progress on my $300 82 toyota 4x4 reg cab 934rnr 95.5-2004 Tacomas & 96-2002 4Runners 8 10-07-2004 07:55 PM
2009 InternetBrands, Inc.
