| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
60k mile maintenance questions
#2 (permalink) |
Yeah, you can wait on the timing belt to 90-100k. Don't bother with the water pump either. Get the belt and pump done at the same time because whoever does the belt is gonna have the front of the engine apart anyways so its just more convienient that way.
I'd change the fuel filter soon too, saw that you bought it, its pretty easy to do, just a little messy. Oh yeah, check the PCV valve, take it out, shake it, if you don't hear a rattle, replace it, costs like $5 at the most. Might want to look into cleaning the MAF and the throttle body too, also pretty easy. Just be careful around the throttle position sensor, its a spendy replacement (my dealer quoted $90) if you break it. |
#3 (permalink) |
Thanks, I'll check out the PCV valve and clean out the intake.
I changed the fuel filter, belts, and coolant today. It seems to run better, but it takes a bit longer to start. I'm pretty sure I got the filter on right (IN from fuel tank, OUT to engine). J
__________________
99 4Runner 4x4 Limited w/ SC and TRD exhaust URD FTC, 318cc FI, Copper Denso 5302, Cartech FPR. Next: 2.2" pulley; thermostat; Hayden transcooler. Some other toys: 94 RX-7; 00 Yama R1; 125cc TaG kart; 34cc GoQuad; 32cc GoPed; etc... |
#4 (permalink) |
Quick question. When did they put the timing belt on 4X4's? I have a 94 and it has the timing chain.
#5 (permalink) |
What engine Toby?
What is your rig and what engine?
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#6 (permalink) |
94 Pickup with the 22RE
#7 (permalink) |
The 3.0 V6 and the later 3.4 V6 are both timing belts. Not sure about the new 2.7 I4 (probably also belt). From what I've read, when a timing belt goes, the engine stops. If a timing chain goes, the engine self destructs. (22R and 22RE engines) The 94 pickup was available with the 22RE (I4) or 3ZVE (V6) here in the states.
__________________
#8 (permalink) |
Thanks for the info.
#9 (permalink) |
22re timing chain issues.....
My '86 22re had a timing chain issue at 112k... I bought the vehicle with 99k on it.
The chain guides are plastic and a piece broke and fell into the bottom where the chain then proceeded to jump a tooth. I had to replace 4 exhaust valves and two intake valves. Then one - two years later I had a coolant leak into the the number two cylinder. I purchased a reworked 22r head and bolted it up. Good thing this happened because I was losing oil on startup because the machinists (A Holes), said they had replaced the valve seals and didnt. RULE OF THUMB - Keep 50-50 antifreeze or better in the vehicle. Always replace PLASTIC timing guides. The motor now has 178k and runs better then my 1987 runner with a 22re, my guess is compression increased due to the reworked head being shaved....... 22Re is one kick butt motor...... Mike :confused: |
#10 (permalink) |
2.7L
The 2.7L has a timing chain also. It does not have screw type valve adjusters. Its really Diff. engine than the 22RE.
As for the timing belt on the V-6, 90k is ok for all Toyota's. All V-6 models use a thicker and wider belt than the 4-Cyl. Personally, in 15 plus years of wrenching , Ive never seen a Toyota V-6 belt break. Ive seen them with over 120k on the O.E.M. belt. Im sure that they would break given some crazy high miles. But if your water pump is leaking at 60k, replace the belt too. Its no good to re-use a T-belt. If You do make sure that its installed in the same direction that it came off. Kxpaul. |
#11 (permalink) |
What is the full list of tasks for a 60k mile maintenance? Does someone know specifically? And what would it cost to do yourself vs stealership?
Thanks Danny
__________________
2002 Thunder Cloud Sport Edition 4WD: Valentine One Radar Detector Deckplate Mod Sunroof Deflector DRL disabled Husky Floor Mats & Trunk Toyota Hood Protector TRD Air Filter --------------------------------- "For God so loved the world, that He gave His only begotten Son, that whoever believes in Him should not perish, but have eternal life.".....John 3:16 |
#12 (permalink) | ||
Quote:
__________________
Eric 88 4runner Quote:
#13 (permalink) |
Thanks Filthy
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2000 Tundra TRD 60k maintenance | realchef | Offroad Tech | 0 | 08-21-2005 10:11 PM |
| 60k mile tune up | Poke Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 06-07-2004 12:27 PM |
| 60k maintenance... | invincibletoy | Maintenance & Repair Archives | 7 | 12-13-2003 12:45 PM |
| 60K maintenance Question | Outkast` | Maintenance & Repair Archives | 4 | 03-22-2003 10:13 AM |
| 60k Maintenance | LSUMatt1514 | Maintenance & Repair Archives | 8 | 11-14-2002 04:27 PM |
