4x2 tranny - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-26-2005, 02:46 AM   #1 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
4x2 tranny
so i broke my 4x2 tranny. have no clue what it is... think its a w55 or a w56
i am almost positive my truck has a w56 2wd tranny. unless the w55 appears exactly the same?....
jimbo74 is offline
Old 10-26-2005, 04:54 AM   #2 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
There should be a plate somewhere on the trans that has a code on it. It probably won't say W55 or W56, but some other Toyota number that you'll need to cross reference with a chart.
Now we need to dig up that chart....
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 10-26-2005, 07:51 AM   #3 (permalink)
Albuquerque Jim's Avatar
Here's your chance, start your 4x4 conversion. Stick the 4x4 tranny and transfer case in and have your drive shaft shortened. Worry about the front when you get an axle.
__________________
'00 SR5, "Highlander"
Dual Cases, Aisin Hubs, E-Lock'd, Cryo'd, Chromo'd, ARB'd, 315's, Sonoran Steel Bumper, Lift & UCA's, 4 Crawl 1" BL, Armored...etc.
F-Toy #081 in progress
Dual Cases, 30 Splines, 5.71's, E-lockers, Hydro-Assist, 37's, DOM Hendrix Chassis, 80Proof, ORS, Sonoran Steel...etc.
Albuquerque Jim is offline
Old 10-26-2005, 08:29 AM   #4 (permalink)
jimbo74's Avatar
i was actually thinking about that... now instead of having my driveshaft shortened, can i get a stock driveshaft from a short bed, std cab 4x4? i know i will also need the crossmember... i am trying to keep this as cheap as possible though and 4x2 is fine with me if i can get it up and running soon..... without my truck running, i cant work... and without work, my available $ gos into negative numbers....
jimbo74 is offline
Old 10-26-2005, 01:03 PM   #5 (permalink)
kyle_22r's Avatar
SAS time! i think you'd at least need to get the t-case end flange yoke for the driveshaft, don't the 2wds use a slip yoke(splines on the driveshaft go into the tranny)?
of course if you want to keep it a 2wd, easiest way would be to find a 2wd truck in the junkyard. if you want a straight answer on if you can convert a 4x4 transmission to a 4x2 one, go over to marlin's site and ask on his board. they can set you straight
it's a beautiful day outside, i'm trying to get my engine running again but i've been having thoughts of starting the drivetrain/suspension build today...
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 10-26-2005, 05:08 PM   #6 (permalink)
Glenn's Avatar
How did you break it and what is wrong with it?
__________________
-Glenn-
Glenn is offline
Old 10-26-2005, 07:47 PM   #7 (permalink)
jimbo74's Avatar
the output shaft snapped.... too much power.....
jimbo74 is offline
Old 10-26-2005, 09:39 PM   #8 (permalink)
Waterboy's Avatar
Quote:
You sure it's not just 20 something year old parts?
Seems like a 2wd transmission would be a cheapier route and get you back on the roads faster. If you go 4wd you'd have to buy a transmission, transfer case, driveline and crossmember and get it all stuffed in there.
__________________
-Jesse
'92 Pickup SR5 V6 *sold*
Downey headers - Flowmaster 40 - drilled rotors - 1" 4crawler body lift - BJ spacers - 33x12.5 AT - OME shocks/stabilizer - Arma bedliner - 35% tint on top of factory - roll bar - Stubbs sliders...one mean mall crawler
'99 Chevy S10 Xtreme
'96 Jeep Cherokee (wife's)
'02 Honda CBR 954rr
Waterboy is offline
Old 10-26-2005, 09:41 PM   #9 (permalink)
Rivalred's Avatar
Bite the bullet, get the money one way or another and make it into a 4WD. Easier for you to make that vehicle into a 4WD than it would be for me to do it to my 05 Tacoma, that is for sure.
__________________
Traded in: 2005 Tacoma DC PreRunner SJ Package Silver Streak Mica
Traded in: 2007 Camry LE Silver
Rivalred is offline
Old 10-27-2005, 12:24 AM   #10 (permalink)
jimbo74's Avatar
actually i dont think its 20 year old parts... figuring its a w56, and my truck is a 22r, it was actaully for a efi which had mroe power... it probably had more to do with my heavy foot and pushing 31s on 3.07 gears with a centerforce dual friction clutch......
yes, it would be quite easy for me to do an sas and 4x4 conversion, and i might, but i need to get back on the road first and foremost.....
if someone can sell me a 4x4 tranny, tcase, crossmember, and rear truck driveshaft for a std cab shortbed, for cheap, i will go that route
jimbo74 is offline
Old 10-27-2005, 12:26 AM   #11 (permalink)
stevrock's Avatar
Send a message via MSN to stevrock
Bahahaha, too much power. You're using a what? 22r? Not enough strength to turn the big ol' tires.
The tranny from a 4wd is not the same, so either start your 4X4 conversion or get another tranny for a 2wd.
__________________
-Steve H.
88 4Runner: 22RE, 5 speed, soft top, 3" body lift
Quote:
Originally Posted by Flygtenstein
I have yet to meet a woman, no matter how physically beautiful, who was purely pleased to be naked. Maybe it was my shadow peering in the window, but I digress.
stevrock is offline
Old 10-27-2005, 12:32 AM   #12 (permalink)
jimbo74's Avatar
hey my 22r has liek over 100 hp and with the way i drive, it probably shock torqued it......
yeah i found htat out earlier today... i guess internally they are the same, but the output shafts are different the 4x4 has a female output and the 4x2 has a male output shaft
jimbo74 is offline
Tags
4x2, slip, splines, toyota, yokes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
31's on a 4x2??? fuel36 86-95 Trucks & 4Runners 10 06-10-2006 10:08 PM
Difference between sr5 Tacoma (4x2) and Prerunner(4x2)? paranoidandroid 95.5-2004 Tacomas & 96-2002 4Runners 6 07-03-2005 11:49 AM
WTF is a 4x2? Dr. Zhivago 95.5-2004 Tacomas & 96-2002 4Runners 39 04-12-2005 09:24 PM
Offroading with 4x2 slyang1012 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 15 08-26-2004 03:05 PM
4X4 vs 4X2 darktiger 95.5-2004 Tacomas & 96-2002 4Runners 4 10-28-2003 01:54 PM
2009 InternetBrands, Inc.
