| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3rd Generation rear window/wiper issue
#2 (permalink) |
Sponsoring Member
I had a similar problem with mine a couple of years ago...
There's a limit switch inside the gearbox that drives the window. With the window going up and not stopping, then it sounds like the switch is either out of adjustment or somehow fubar'd. The switch has an additional function which is to control the wiper. The wiper won't run unless the the window is up all the way. So, fix the fact that the window motor doesn't want to stop, and you'll get the wiper to work. ![]() Personally, I ended up disconnecting the window controller and ran the window up to the top of the track and left it. That allowed the wiper to work though I lost control of the window.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#3 (permalink) |
You need to get a hold of an electrical diagram if you want to solve it efficiently.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#4 (permalink) |
Thanks for the suggestions. I checked on the limit switch and unfortunately it seems to be working as it should. While I was testing it though I found a new symptom. I ran the window down again with a battery and then turned the key off and took it out of the ignition and when I plugged the motor wires(for the window) back in it still ran the window all the way up. I pulled out the old meter and even when the car is off and key is out, I am getting 12 volts to the window motor. Wierd...
Your right, I do need an electrical diagram. Do I have to get that from the dealer or is there another place I can find one? Thanks again for the suggestion |
#5 (permalink) |
Thanks everyone. Problem solved. I got the wiring diagrams and had totally forgotten about the window controller switch integrated into the tailgate lock. It was stuck in the on position over-riding all the other controls. I disconnected it and now the window and wiper work. I'll see if I can get a cheap replacement or I'll just leave it unplugged for now. Just chalk this one up to a learning experience.
#6 (permalink) | |
Quote:
__________________
| Tags |
| 3rd, 4runner, gen, problem, rear, relay, runner, shutoff, stop, switch, tailgat, tailgate, toyota, window, wiper, wipers |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| rear wiper and window | j | 86-95 Trucks & 4Runners | 0 | 08-30-2006 11:40 PM |
| Rear Window Wiper Problems | vegascoug | 86-95 Trucks & 4Runners | 6 | 02-22-2006 08:32 PM |
| Rear Wiper issue. | Yota4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 21 | 01-08-2005 03:08 PM |
| rear window wiper | tuckeraustin | Maintenance & Repair Archives | 1 | 12-09-2003 03:19 PM |
| Rear window wiper | The4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 11-12-2003 09:12 AM |
