3.0 Head Gaskets, $2,710.26!!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-16-2005, 02:17 PM   #1 (permalink)
4x4Lamm's Avatar
My 4Runner is back from the shop, all the headgasket and related repair work is done. Grand total is................................................ ...............
$2,710.26!!!
On the plus side, the entire top end of the engine was rebuilt, so it should be fine for a long time.
Here is the list of what was done:
-machine heads
-new knock sensor
-new knock sensor wire
-new water pump
-new exhaust bolts/studs (manifold)
-new idler pully assembly
-new idler tensioner pully
-new thermostat
-new head gaskets (kit)
-new head studs
-new air filter
-new AC belt
-new power steering belt
-new alternator belt
-new coolent
-new valve seals
-new cam seals
-Replaced a few missing bolts on the tranny bellhousing too
So now the build-up can continue. Lift and tire/wheels in a week or two.
I'm still fighting with Toyota and Cain Toyota over all this, I will be sure to post the results of that...
Lamm
__________________
-1992 4Runner SR5, Destroyed by fire. Lots of mods. I will miss it.
-1995 4Runner SR5 Limited, Also known as the money pit. Becoming a trail rig now.
-2004 Tacoma SR5 TRD, My new daily driver. I love this truck!
4x4Lamm is offline
Old 11-16-2005, 02:21 PM   #2 (permalink)
FilthyRich's Avatar
WOW--not cheap at all.
Glad it is all fixed. Let the mods continue
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 11-16-2005, 03:29 PM   #3 (permalink)
AgRunner06's Avatar
Send a message via AIM to AgRunner06
That's why I hate the 3.0. You probably could have had a reman w/ a warranty put in for that price. I think the Orient Engine is $2K.
I hope she runs good.
__________________
"I'm your huckleberry." - Doc Holiday
- '93 4runner - Sold!
Current Ride - 2001 Chevrolet Silverado 1500 ext.cab, pewter, 5.3L, 3.42s, fully loaded, 68K miles.
FREE ROCKET!!!!
AgRunner06 is offline
Old 11-16-2005, 05:14 PM   #4 (permalink)
4x4Lamm's Avatar
So far so good. Runs better than my mom's 03 Highlander.
A few long trips tomorow will yield better results.
Lamm
__________________
4x4Lamm is offline
Old 11-16-2005, 05:16 PM   #5 (permalink)
Rivalred's Avatar
Yikes... Would a crate motor be cheaper?
__________________
Traded in: 2005 Tacoma DC PreRunner SJ Package Silver Streak Mica
Traded in: 2007 Camry LE Silver
Rivalred is offline
Old 11-16-2005, 06:07 PM   #6 (permalink)
4x4Lamm's Avatar
Well, labor was $1300 and there was about $150 on tax alone with the parts, so I doubt a crate motor would have been cheaper installed.
Lamm
__________________
4x4Lamm is offline
Old 11-16-2005, 11:17 PM   #7 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
Quote:
Lamm
maybe not through toyota but somewhere else
__________________
Dan
95 4runner 3vze A/T
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 11-17-2005, 09:18 AM   #8 (permalink)
4x4Lamm's Avatar
Its possible a Jasper motor or something would have been better in the long run, but whats done is done. And now I need some OT.
Lamm
__________________
4x4Lamm is offline
Old 11-18-2005, 11:27 PM   #9 (permalink)
abalagtas's Avatar
Send a message via Yahoo to abalagtas
$2,710.26!!!
-machine heads
-new knock sensor
-new water pump
-new thermostat
-new head studs
-new air filter
-new AC belt
-new coolent
-new valve seals
-new cam seals
Lamm
I feel your pain. I just got my rig back too. My damage was $2,300.
-2 new core heads
-machine heads
-new knock sensor
-new idler lower bearing
-new idler upper bearing
-new thermostat
-new coolent
-new spark plugs
-distibutor cap
timing belt and drive belts were changed 5 months ago.
It does run a lot better.
__________________
Semper Fi,
Alfred
'91 4Runner SR5 4wd 3.0 V6
'10 Scion Xb
abalagtas is offline
Old 11-20-2005, 11:25 AM   #10 (permalink)
abalagtas's Avatar
yikes....looks like my problems aren't over.
The engine runs great now, but the damn coolant is still leaking from pretty much the same place when I brought it in. On the passenger side btw the fire wall and the engine. I can only follow the leak up as far as the X-over pipe. It only starts leaking after the T-stat opens. It doesnt leak when the engine is off or immediately on startup.I thought it was the HG, but now I don't know. Called my mechanic yesterday and he offered to drive down to my place and check it out today(Sunday), so I wouldn't have to bring it all the way back to his shop if it was something small. His shop is 40+mi from me.
Are there heater hoses down that low behind the engine? I do have a rear heater and I followed those, but didn't see a leak.
I do hope it is something simple....the engine is running so smooth.
__________________
Semper Fi,
Alfred
'10 Scion Xb
Old 11-20-2005, 11:47 AM   #11 (permalink)
JamesD's Avatar
Check out my thread: http://www.yotatech.com/showthread.php?t=68448
James
__________________
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569
Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/
JamesD is offline
Old 11-20-2005, 04:30 PM   #12 (permalink)
abalagtas's Avatar
Quote:
Originally Posted by SRV1
Thanks James,
I can actually see that hose and it doesn't appear it is leaking.
The shop owner and mechanic had a pow-wow and think it may be one of the 3 drain plugs on the rear of the block. They looked coroded, but it didn't appear to be leaking when they had the engine a part.
I'll be dropping it off tomorrow for them to take a look at it.
__________________
Semper Fi,
Alfred
'10 Scion Xb
Old 11-20-2005, 05:10 PM   #13 (permalink)
Just fixed my behind-the-motor-between-the-firewall coolant leak today. Mine just turned out to be the clamp on one of the heater hoses wasn't on all the way. Maybe your rear coolant passage where the temp sensor, cold start sensor, and one other sensor is attached to is leaking at the base where it sits on the intake manifold? When it starts leaking, shut it down, let it cool for a few minutes and pry your hand next to that passage and feel for a leak. Only freeze plugs I know other than on the sides of the block and under the intake is 2 in the back of each head.
callmej75 is offline
Old 11-20-2005, 05:37 PM   #14 (permalink)
YeloSub7's Avatar
Send a message via AIM to YeloSub7
I spent about $500 on mine and I did it myself!!!!!!!!!!
__________________
-Jake
1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-35" BFG M/T-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders-TG Front Bumper
SAS Build-Up
Old Rigs:
'85 4Runner (RIP)
'95 4Runner (sold)
YeloSub7 is offline
Old 11-21-2005, 08:20 PM   #15 (permalink)
abalagtas's Avatar
Welp.....that was it. The horse shoe hose from the bypass to the sensors was leaking.
I think this was my original problem. However, the work they did on engine was needed and runs so much better. I think I was running on only 4.5 cylinders. There is so much more power now....for a 3.0.
__________________
Semper Fi,
Alfred
'10 Scion Xb
Old 11-22-2005, 04:48 AM   #16 (permalink)
good deal...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3.0 head gaskets Kerry 95.5-2004 Tacomas & 96-2002 4Runners 9 03-08-2009 09:35 PM
head gaskets daveo 86-95 Trucks & 4Runners 5 12-04-2006 02:39 PM
hilux head gaskets Tin Tin 86-95 Trucks & 4Runners 1 10-07-2006 01:21 PM
engnbldr.com head gaskets kpaxfaq 86-95 Trucks & 4Runners 7 09-06-2006 03:55 PM
2 head gaskets in 3 months??? Maverick 95.5-2004 Tacomas & 96-2002 4Runners 4 09-19-2004 12:21 PM
2009 InternetBrands, Inc.
