| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22re timing chain replacement
__________________
'94 std cab 22re 4x4 stock |
#2 (permalink) |
I found I had to remove one or both of the chain guides to get enough slack in my chain to get in into place on the camshaft.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
i think i used a rubber hammer, but there is a better method i'm sure.
__________________
1992 "Truck" 1978 Land Cruiser FJ40 pig and elephant DNA just won't splice :( ***DO NOT CLICK HERE*** |
#4 (permalink) |
Can't you push the tensioner in to give you more slack to get the spocket on the end of the cam??
#5 (permalink) |
It helps to reach down there with a large breaker bar or long stick of metal to pry the tensioner back in and then you'll have just enough slack to slip the cam sprocket on.
#6 (permalink) |
You have to push back the tensioner. When I replaced mine I wedged a small block of wood with a string attached to keep the tensioner pushed back. After the sprocket is attached to the cam just pull the string and the wedge will come out.
#7 (permalink) |
the way i get my cam sprocket on(no way i can put it on by hand) is to stick a small prybar in one of the holes, rest the angled part on the camshaft, and walk it up onto the cam
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
| Tags |
| 22r, 22re, 92, 93, 95, cam, chain, pictures, repair, replace, replacement, slipped, timing, toyota, wedge |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE Head Gasket and Timing Chain Replacement PICS | all_terrain17 | 86-95 Trucks & 4Runners | 205 | 09-11-2009 05:05 AM |
| 22RE Spark knock after timing chain replacement | Brown | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 09-18-2007 02:29 PM |
| Timing Chain replacement.. | Mister Willie | 84-85 Trucks & 4Runners | 1 | 07-20-2007 08:10 PM |
| 22re timing chain/set timing/rtv/headremoval | brendonv | Maintenance & Repair Archives | 4 | 09-20-2005 07:18 AM |
| 22RE - Timing chain replacement estimate | pinemind | Maintenance & Repair Archives | 4 | 05-16-2005 09:52 AM |
