| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22RE dies on startup - need help fast!
#2 (permalink) |
Well i know that the white grease in your diagnostics terminal is dielectric grease, and it's there to stopp water from shorting it or preventing any sort of condensation.
Sounds like a fuel system problem... I think (and someone tell me if I am wrong, PLEASE)that if it was REALLY a vaccuum problem, then it would only affect the idle, and you could rev it up, and the engine would instantaneously smooth out. At even 5% throttle, the vaccuum system isn't PULLING, it just flows. Donny
__________________
1998 Tacoma Standard Cab 4x4 -5 Speed -2.7L 3RZ-FE -80,000 Miles -custom ISR Mod -Purolator Fuel Filter -Royal Purple -Marlin Crawler Shift Stuff -Lots of Plans -No Money |
#3 (permalink) |
have you retrieved the codes yet, that would help out allot, the grease in the connector is there from the factory, it helps stop corrosion
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs |
#4 (permalink) |
Too bad it's not OBDII...
__________________
#5 (permalink) | |
Quote:
Really I just want to get it back to where it was earlier today: running fine, with a check engine light. Upon further thought, there's a good chance I bent something inside the MAF (underneath the black plastic piece siliconed into place on top of the MAF bracket). Would that cause the problem? Is there any way to get in there and fix it? Is there any way to get it running well enough to just get it to a garage so I don't have to pay for a tow? |
#6 (permalink) | |
Quote:
I did a little more research, and think I've figured out that I have an AFM (which would explain why it didn't look the way I expected and why I screwed things up by yanking parts of it out), not an MAF, and that I most likely bent something in removal and re-installation of the spring. So I think cutting open the plastic cover and fixing it from above might be the only option... unfortunately, I don't know what it's supposed to look like. Below is the best picture I can find on the web. Any additional advice before I go ahead and wing it? |
#7 (permalink) |
sounds like the maf was damaged upon reinstallation... the maf can make it die right after starting..... well, the maf did on my explorer when is was really dirty after a rollover
#8 (permalink) |
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#9 (permalink) | |
Quote:
Anyone have a good picture of the inside of an AFM? I'm pretty sure I didn't break anything, I bent the appropriate parts back into place. Just need to know what it's supposed to look like. Last edited by ohio; 07-05-2005 at 09:03 PM. |
#10 (permalink) |
Some here:
http://www.4x4wire.com/toyota/minutemods/afm/ Did you try the fuel pump test jumper? It'll bypass the AFM and run the fuel pump any time the ignition is on.
__________________
#11 (permalink) | |
Quote:
I think if I just reassemble the AFM correctly, it should work. The two configurations that seem to make sense don't work. 1. If I put the feeler to the outside of the contact/spring it does push the contacts together, but then I don't think it opens up far enough to allow air flow. 2. If I put the feeler to the inside of the spring/contact, it can rotate fully, but I don't see how the contacts will ever be pushed together... I tried both, and neither works. Both fire right up, and then die in about 3 seconds or so. I don't know how many more starts I can get out of the battery. I'm going to have to have the truck towed in the morning, because it can't be parked in it's current spot during the day... I didn't do the work in my garage because I was messing with solvents. I'm an idiot. edit: in the picture from 4x4wire it looks like the feeler is to the outside of the spring, but I can't quite tell. If that's the case, how does the thing rotate? Last edited by ohio; 07-05-2005 at 09:38 PM. |
#12 (permalink) |
Okay, so this is what I've learned:
1. 22RE's don't have an MAF (mass air flow sensor), they have an AFM (air flow meter) 2. Don't mess with the inside of an AFM. When assembled, they're bombproof, but if you take them apart they are very fragile. You will not get any performance gain from cleaning an AFM. They're sealed and clean inside (mine was clean even with a K&N filter and 180k). They also cost about $1000 new from toyota, ~$250 from a junkyard, or ~$200 for a non-OEM reman. 3. The ECU on 92 pickup has hardcodes that don't clear with a pulled fuse or battery cable. So even if you've fixed the problem that was causing a CEL, the CEL may still appear until you've hooked up a reader and cleared the ECU. So my truck was probably just fine, until I started messing. So it was an expensive lesson (~$300 plus most of my day off). On the bright side, I was debating whether to join AAA... well, the free towing made it worth it. |
#13 (permalink) |
Something I've noticed on my '87 'Runner: If you pull the plug from the AFM you have to pull the EFI fuse or the battery cable (neg, of course!) before you put the plug back on or it'll do just what you're describing. It'll start, run a few seconds, then die. I got very frustrated by this before I found out about having to reset the ECU. I don't know WHY this is, but it sure IS on my truck. Prolly a quirk of the ECU.
A little late, I realize, but better late than never...?
__________________
"Well, that didn't work!" - Baron Manfred von Richtofen, during the latter portion of his last flight '87 4Runner, 22RE, pretty much stock, on it's 3rd head now, 146 k miles '87 2WD P/U, 22R, stock everything, mostly factory everything too, 286 k miles, beater truck. 10 year US Marine and proud of it. One of my daughters is an active duty Marine, another is Navy! |
#14 (permalink) |
Okay heres the deal...You most likely screwed up the VAFM (vane air flow meter) when you took the cover off. Did you undo the 2 small screws holding the cable into the VAFM? If you did you for sure messed it up. No big deal this is what I would do.
If you have someone with the same part # on top of the VAFM then swap yours out with there and see if thats solves the problem. If it does, which it should, then buy a used one from a junkyard ($100 no more) or look on ebay for one there cheap. If you started messing with it you wont be able to get it back to spec trust me. Good luck. |
#15 (permalink) | |
Quote:
Unfortunately, because I needed to get to work and the fact that it was parked on the street in the city, I had to it towed to a garage and fixed. It'll run me ~$300.... ouch. Lesson learned. |
| Tags |
| 22re, pcv, purolator, valve |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22re dies | Sonofmayhem | 86-95 Trucks & 4Runners | 4 | 06-09-2007 11:33 PM |
| 22re initial startup problem (very long) | justinking060310 | 86-95 Trucks & 4Runners | 16 | 12-15-2006 01:55 PM |
| 22re startup idle is low | Yamaha+Toyota=Fun | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 11-10-2004 02:55 PM |
| 22RE startup | Wildcat_4R | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-10-2004 09:29 PM |
| startup tap or knock on 22RE | ironhead31 | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 03-07-2004 08:24 PM |
