Engine Swaps Swapping an engine in your Toy, here is where to learn how
swapping out a 22re for a 22r
Old 12-04-2008, 02:09 PM
khamblin's Avatar
Hey i have an opportunity to get a 22r motor for my truck. My truck is a 1992 4runner with a 22re in it. The motor available to me is a 22r, out of a toyota celica, it may be a 1984 but i have to go confirm that. if it is a 1984 is it possible to swap the two motors. I've heard that a 1985 22r can be swapped fairly easily, but i would like to know if it is possible to do that with a 1984.
Any help would be greatly appreciated so that i can know if i can make this swap or not.
Thanks
Old 12-04-2008, 04:40 PM
tjanelle's Avatar
why do you want to go from efi to carb
Old 12-04-2008, 05:17 PM
khamblin's Avatar
it's just the engine that's available to me right now. thats all. if i could find a 22re then i would use it. but i have found a 22r available so i just want to see if i can use it. thats the only reason i would do that.
Old 12-10-2008, 08:08 AM
b/s rules's Avatar
same thing i did, i bought my 91 for 125 bucks with a bad 22re, bought a 22r for 500 that had just been rebuilt, i had some vacuum issues but once we got i straightened out it runs freakin' great. vertical climbs is the only time i had carb problems, ran a vent hose off the front venturi of the carb to keep fuel out of the back, all my buddy's are running 22re's and wishing they have the power of mine. i couldn't find a 22re for less than 1000 bucks around here. "put a magnet on the bottom of the skinny pedal and let it eat!"
Old 12-10-2008, 08:14 AM
thetoyminater's Avatar
thats what i did i got a 22r for 200 bucks just needed a head gasget and i swapped the carb for the EFI on my 22re
Old 12-13-2008, 02:49 PM
TrikeKid's Avatar
They're essentially the same engine, so as long as it's a late style 22R you can swap all of your EFI stuff onto it and it will be just fine.
sandyota
02-04-2021 11:16 AM
mskalmus
05-28-2017 07:51 AM
deepmarsh
08-06-2015 03:44 AM
cars-guy
07-11-2015 07:51 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: swapping out a 22re for a 22r
