sbc swap in 89 yota, lift??? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-19-2009, 05:58 PM   #1 (permalink)
Send a message via AIM to RDNEKkid
im trying to swap a sbc in my 89' 4x4 pickup, and i was woundering if a lift was needed at all.
i havent decided weather im gonna use the adapter to my stock tranny or getting a tb350, i gues it depends on what cheaper and eaiser. any info is greatyl appreciated
thanks
RDNEKkid is offline
Old 04-20-2009, 12:00 PM   #2 (permalink)
RevNL's Avatar
Yes.
2 or 3 inch body lift for clearance up top.
Suspension lift or a special oil pan for clearance on the bottom.
Or a solid axle swap.
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift
RevNL is offline
Old 04-20-2009, 12:41 PM   #3 (permalink)
so if i do a solid axle swap in the front, i wont need a lift, and if need be just drop shackles for the rear??
thanks for the info
RDNEKkid is offline
Old 04-21-2009, 03:07 PM   #4 (permalink)
RevNL's Avatar
With the SAS, you can mount the engine low enough to not need a body lift but the SAS involves a bit of lift on its own. There are threads in the solid axle swap section covering low lift conversions.
Beware. I'm using a 700R4 and NP208 with no body lift. What I gained by not lifting the body, I lost from the transfer case hanging too low. Really low. It needs to be rotated up but that's a task for another day.
__________________
RevNL is offline
Old 05-17-2009, 05:30 PM   #5 (permalink)
sperkinsnwfl's Avatar
i have a 91 with a 350 /turbo350 advance adapter to the stock case mine just has a stock pan reshaped via 5pd. hammer not pretty but it works . i have a 3"bl and the chevy hei dist. its pretty tight with the sas and b/l you can drop the engine mounts low enough to get the distributor off the firewall or you could swap a ford motor in which is what i wish mine had ..... either way a v8 in a yota is a lot of fun nothin like smoking some 33's down the road
sperkinsnwfl is offline
Old 10-10-2009, 11:13 PM   #6 (permalink)
im doing a 350 swap right now and if you go to advanced adapters they actually have a booklet for chevy v8/v6 swaps, they say it is best to have a sas with suspention lift and they recommend a body lift of at least 2" for better clearince. but another thing to think about with a 350 swap its a little harder for the fact that the distributer is in the back of the motor unlike a ford with the distributer in the front. for me i already had a built 350 in my garage but even if i didnt i could put a ford motor in my truck, im too much of a chevy guy
liftit is offline
Tags
89, axle, lift, sbc, straight, swap, toyota, yota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
91 4Runner SBC swap Daytona675 Engine Swaps 5 05-29-2009 06:32 PM
91 yota swap? matt91yota Engine Swaps 3 01-28-2008 08:07 PM
Anyone with a SBC 350 swap use an R150? Adam F The Fab Shop 7 10-09-2007 02:25 PM
350/v8/sbc swap. Anubiscougar 86-95 Trucks & 4Runners 3 12-16-2006 10:11 PM
Engine SWAP - SBC yotaman17 86-95 Trucks & 4Runners 9 01-25-2006 07:01 PM
2009 InternetBrands, Inc.
