| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
rebuild 22re or engine swap
#2 (permalink) |
Also...if i was going to rebuild it. Is the engnbldr kit on ebay a good buy? what else would i need?
ebay |
#3 (permalink) |
do the rebuild, check out LcEngineering,,,,,,,22re's a wonderfull motor lasts a million years, makes no power, but then it won't break.............my re has 265k..broke a spark plug off in # 4 cyl, pulled head n head was cracked, put a new one in and bingo, i am good to go for 2 more years
#4 (permalink) |
Howdy climber. I think if I were n yer shoes, I"ll rebuild that head, make sure the timing chain cover is good, get new timing set, oil pump, new spark plugs and wires, plus the gasket set, man it wont cost you no more than $500 your truck does'nt need a complete rebuild with ONLY 140K miles, if you change those parts that puppy will be ready to double those numbers.
#5 (permalink) |
what make you "think" you blew the HG?
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS |
#6 (permalink) |
i just went through this same delima. had a tired 22re, so i rebuilt one with o/s stainless valves, port and polish, rv cam, full rebuild kit and an aisin clutch. after all of that, i dont like that with the rv cam i start making power so high up in the rpms. i should have went with the crawler cam. with 4:88's and 33"s, im still having problems holding a decent speed on hills and even on the flats with a head wind. if i were to do it over again i would go with a 5mge or 7 mge. im already looking at a 7mge swap and sell my motor while its still fresh.
#7 (permalink) |
Super Moderator-Sponsoring Member
Staff
Rebuild what you have.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#8 (permalink) |
What is a 5 mge or 7 mge ----
WALT |
#9 (permalink) |
Keith black rebuild from 22re.com. New japanese internals w/ 9.7:1 hyper pistons and a 272 cam. Good power,great torque.
__________________
Piston selection and Camshafts.Who knew? |
#10 (permalink) |
I say rebuild it, if you feel competent in your abilities to do it yourself you can do most of it with simple hand tools and shouldn't cost you a lot to rebuild it, a swap could cost a lot more by the time you track down all the parts you need and fab new motor mounts and all.
__________________
86 Regular Cab, 31x10.50, 22r, 5sp, Marlin 1200lb Heavy Duty Clutch, Smittybuilt Rear Bumper and 275K miles and counting 89 4Runner 3.Slow 5sp 31x10.50 in need of some help but I have plans for it (in no particular order): Front bumper and winch, 2” Body lift, BJ Spacers, Locker 33's and more |
#11 (permalink) | |
Quote:
His master rebuild kit is almost everything needed to rebuild the whole motor for $209 plus $20 shipping so $229 total I have one sitting here for my rebuild and he did a few parts swaps for me that replace parts in his kit I already had no extra charge you just can't beet that kind of service. I know SUPERBLEEDER is using his kit as well on his rebuild and there are many others here using his stuff so that should say a little bit about his stuff if you want a little more reassurance As for the headgasket I found out the hard way it may not be your head gasket after all , check your timing cover seems that if your chain rubs through your cover it will pick up a water leak from the water passage leaking into the cover giving the oil mixed in the water look
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. Last edited by olharleyman; 07-07-2009 at 11:09 PM. |
#12 (permalink) | |
Quote:
7mge's were in 86-92 supras'. it's a 3.0l straight 6 |
#13 (permalink) |
X2 and check to see if the timing cover is ok ,like oharleyman is suggesting
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, Homemade Roof rack.33x10.50,15 KM2 1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ |
| Tags |
| 22re, black, keith |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE engine rebuild questions | Brainlessmoth | 86-95 Trucks & 4Runners | 2 | 05-05-2009 01:44 AM |
| Engine Rebuild Help -22re | Scroff | 86-95 Trucks & 4Runners | 8 | 11-02-2008 04:57 PM |
| Engine swap/ rebuild nightmare. Help... | cnctony | Engine Swaps | 4 | 08-29-2008 09:14 AM |
| 92 toy engine swap 89 rebuild | rose | 86-95 Trucks & 4Runners | 34 | 01-04-2006 06:08 PM |
| Rebuild or 22R to 22RE swap? | GreeneHoosier | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 08-17-2005 08:08 AM |
