| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
oil pan and motor mount issue
#2 (permalink) | |
i believe you have to swap out the oil pickup tube also(its under the pan
)on a 4wd you can get the pan off with out pulling the motor. not sure on a 2wd though..
__________________
91 Toyota "built not bought" Quote:
#3 (permalink) |
If they are both short blocks, switch the oil pickup like was said and use the 2wd oil pan
I had the same problem but i was going from a tall block to a short block and the oil pickup had a different bolt pattern so i ran the 2wd pan and my front axle dented it ![]() Edit: Oh and i think you have to remove the tie rod and front xmember to remove the oil pan on a 2wd.. not as bad as it sounds.. like 6 bolts and a little hammering
__________________
. . . I said lie, for me lying under a process tree . . . . Last edited by algranger; 05-16-2009 at 10:28 AM. |
#4 (permalink) |
Super Moderator-Sponsoring Member
Staff
2wd and 4wd pans are different, but same bolt pattern. Just swap the pans/sump.
Donor motor in my 85 ext cab was out of a 92 22R 2WD so all I did was just put a 4WD pan/sump on it and it was golden. ![]()
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale Last edited by waskillywabbit; 05-16-2009 at 10:46 AM. |
#5 (permalink) | |
thanks for clearing that up wabbit
__________________
| Tags |
| motorsport, oil, outfront, pan |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3VZE Oil Pan and Oil Pickup Tube | b18vteceg | Items Wanted | 2 | 04-26-2009 08:17 AM |
| 4wd oil pan onto 2wd motor? it won't fit! | 83Chero | 86-95 Trucks & 4Runners | 3 | 01-10-2009 11:05 AM |
| converting to Mobil1 next oil change, would you recommend drop the oil pan | TC4RNR | 86-95 Trucks & 4Runners | 28 | 01-08-2008 08:27 PM |
| Found the oil leak--oil pan removal? | morrison | 86-95 Trucks & 4Runners | 6 | 12-31-2007 04:16 PM |
