YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-04-2008, 02:33 PM   #1 (permalink)
Toyota_Pilot's Avatar
Exclamation No oil pressure
Just finished my motor swap with a new 22re, its runs but i have no oil pressure. I replaced the oil pressure sensor. When i turn it on the pressure gauge comes off of the peg but its just below the operating arch. what can i check or change without ripping the motor apart again?
__________________
92 DLX Pickup X-Cab
22RE 4X4 manual
4 Inch Trail Master lift
Toyota_Pilot is offline
Sponsored Links
To remove this ad, register today!
Old 09-04-2008, 02:53 PM   #2 (permalink)
its exactly the same as the old engine. It came with a new pump installed by www.sunwestautomotive.com
__________________
92 DLX Pickup X-Cab
22RE 4X4 manual
Old 09-04-2008, 02:58 PM   #3 (permalink)
TOYOTA 1's Avatar
hmm.. do you have a manual one handy?
__________________
91 Toyota stdrd cab short bed 22re 5spd. sas'ed, Yukon 5:29's. 3.5" tuff country e-z ride springs in the front. 5" allpro long travels in the rear. pro comp es 9000 shocks, 12" tg long spline front d shaft. k&n, 35x10.50x15 boggers. cobra cb/ashtray mod, 3' fire stick. etc.
2000 Toyota Tacoma xtra cab sr5, 3"revtek,285/70/17 coopers stt, clear tails, injen short ram intake, obx header, flow master, etc.
2001 Toyota Camry, the girlfriends,
www.22re.com
TOYOTA 1 is offline
Old 09-04-2008, 03:55 PM   #4 (permalink)
a manual oil pressure gauge, no. the repair manual, yes but i didnt see anything on trouble shooting low oil pressure
__________________
92 DLX Pickup X-Cab
22RE 4X4 manual
Old 09-04-2008, 04:04 PM   #5 (permalink)
TOYOTA 1's Avatar
i was talking about a gauge.. see if you can get one then check for oil pressure! that will tell you if its the gauge, or not. eliminate the idea of a faulty gauge.
just my .02
__________________
www.22re.com
TOYOTA 1 is offline
Old 09-06-2008, 07:01 PM   #6 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Use an oil pressure tester and see what your actual oil pressure PSI is
http://www.harborfreight.com/cpi/cta...emnumber=92687
Adam F is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
NEED HELP! - Low oil pressure & leaky oil breather boosted86 86-95 Trucks & 4Runners 4 08-12-2008 09:10 PM
Questions about oil pressure and oil pump replacement on 3VZE ThomasJ 86-95 Trucks & 4Runners 2 11-28-2007 05:39 PM
Oil pressure & Trans Oil Temp Install ?? Jayota 95.5-2004 Tacomas & 96-2002 4Runners 0 07-18-2007 08:59 AM
Oil pressure & Transmission Oil Temp Install ?? Jayota 95.5-2004 Tacomas & 96-2002 4Runners 5 07-16-2007 10:13 AM
Best location for new oil sender (Autometer oil pressure gauge) Bob_98SR5 95.5-2004 Tacomas & 96-2002 4Runners 10 10-20-2004 03:13 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
