new 3.0 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-29-2009, 12:52 PM   #1 (permalink)
Mr.Matthew3's Avatar
new 3.0
Alright this is my first real thread on here so here goes. Okay a few months ago i was out wheeling and my truck died in the middle of a crossing. Got it out and dried and it would'nt start so i went and got a new cap and rotor. She started right up but had a baaad knock. Long story short i ended up with a new 3.0 long block to drop in.
Got the parts from the old motor swapped over with some new paint
Got her in with minimal hassle
sorry bout the crappy pic
Anyway, well my step dad wanted to get the oil flowing to make sure its being circulated so we hooked up the starter just so we could turn it over a few times. Well my battery was barely charged enough just to turn the engine, not enough to get oil flowing though. when i turned the key a wire from the drivers side of the block started burning its casing. As far as i can tell its a ground wire. It's bloted to the block and goes to the ignition coil, heres a pic..
We checked it out and it looks fine still, can't tell why it heated up though. We charged the battery up to try again and now it wont turn over at all. I also have lost power to my front end. my lights wont even turn on, all i get is a rapid clicking sound from in the drivers side of the dash, and from the under-the-hood fuse block.
so this is where im stuck haha, any help would be much appreciated, i want to get her back on the road
__________________
Great things happen when men and mountains meet- Terry Frog
Mr.Matthew3 is offline
Old 07-30-2009, 11:25 AM   #2 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Check the fusible links/fuses in the engine compartment fuse panel. Should have power in and out of them. You might have to unbolt the fuse block from the fender to get at the wires underneath to test, or you might even see a burnt fuse in there.
Double check the wiring to your starter. It probably got pinched or somethng and is grounded out. Don't try to start anything again until you figured out why the negative cable burnt up, or it will happen again.
Adam F is offline
Old 07-30-2009, 01:41 PM   #3 (permalink)
alright ill check the starter cables and the fuse block wires, i already checked for blown fuses but what was clicking in the fuse block was the EFI relay i believe.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
