Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
high comp 20r on propane?
i heard you can put a 20r head on a 22r engine and it will boost the compression a bit. my truck is running off propane and i wanted to know if a 20r head swap would help my power? i already put 4:88s on it but the power is still low. the guy who installed my propane kit said a 20r head would give me 50+ horses. what do you think?
| Sponsored Links |
#2 (permalink) |
well first of all ive never even heard of someone running a 22r off propane before thats new to me lol second of all the 20r doesnt have more power then the 22r i wouldnt think. or are they both 2.4 liters?
#3 (permalink) | |
Quote:
i cant remember what size the 20r combustion chambers are, but most of the power you will gain is due to the intake ports. it will be up in the higher RPM range not to good for wheeling
__________________
Dan 84 4runner sr5 Ford 302 T-18 4spd yota t-case yota front and rear both open 37X13.00 boggers 88 4runner 22re 5spd |
#4 (permalink) |
You need to visit http://board.marlincrawler.com/ for that kind of information. There's a few guys other there that have done what you're talking about.
A 20R head and 22R block propane'd with a turbo would be sweet.
__________________
Greg - http://www.pureyota.com --- you can't fail if you don't give up. Proud dad of a little girl.. 1. 1997 Tacoma - 3.4 auto - SAS'd - DD 2. 1995 4Runner - SAS'd - FJ62 Front - FZJ80 Rear, 40" Iroks - Beater! 3. 1995 4Runner - 3.4 swapped - Baby mobile/Grocery getter! You can lose a lot of money chasing women, but you'll never lose women chasing money. |
#5 (permalink) |
there have been a few write ups on swapping the 20r head onto a 22r block...but lke yotaman says, there are more write ups on marlins board. as far as i understand it the 20r head has two advantages: (1) its valves are larger and they flow better and (2) the deck height is shorter so it slightly increases the compression. hope this helps.
__________________
Wherever, Whenever, However...Tread Lightly! |
#6 (permalink) |
From what I've been reading the valves are actually smaller but the head flows better, OS valves are recommended, and the combustion chamber is smaller which increases compression. That combo will probably work well with propane since it has a high octane rating.
__________________
95 4Runner- 3vze- A/T- 4.88's Currently LC Coils BJ Spacers SAW T-Bars 32x11.50 BFG A/T's 15x8 black Rockcrawlers Marlin Crawler rear bumper Last edited by CC_yota : 06-17-2008 at 09:18 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Propane | endcl | Newbie Tech Section | 5 | 01-13-2008 02:34 AM |
| propane? | spanish-road | Offroad Tech | 4 | 01-13-2008 02:27 AM |
| Unusually High Comp. In #5 | VoxMan | 86-95 Trucks & 4Runners | 4 | 01-06-2008 11:45 PM |
| SURVEY: BFG M/T's or PRO COMP M/T's or PRO COMP XTERRAIN | T-A-Z-M-A-N | Tires & Wheels | 28 | 09-25-2007 01:21 PM |
| 2wd 20r vs. 4wd 20r | MHale | Newbie Tech Section | 2 | 08-03-2007 01:48 PM |
