YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-09-2008, 02:07 PM   #1 (permalink)
mybigred4x4's Avatar
Grand National Swap???
Hey guys I've got a '91 Standard Cab with a 22RE and a 5 speed. We have several Grand National engines laying around, all intercooled ones, so the turbo's not on top of the engine... Anyone ever put one them in a Yota? I've searched all over for a swap but haven't seen one done yet. I'm thinking of using the 2004R with the stock T-Case. Any ideas are appreciated. Also this truck will be more of a pre-runner than a crawler, Chaos Gen. 2 kit, Deavers, and so on. I also have a 4.3 but it is an older carbureted one that has the old tubular manifolds on it.
Please let me know your thoughts.
mybigred4x4 is offline
Sponsored Links
To remove this ad, register today!
Old 01-09-2008, 02:12 PM   #2 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
someone on pirate 4x4 put a Grand National turbo and intercooler on his 3.0, but if you want the whole engine, i can't help you there.
i you do go with the swap, good luck
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l
TOYOTA TOUR 2008
トヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 01-09-2008, 04:11 PM   #3 (permalink)
toy283's Avatar
Send a message via ICQ to toy283
The Grand National swap should be essentially the same as a standard Buick 3.8 V6 swap-the oldest swap common to Toyota pickups. The turbo & intercooler will throw a bit of a wrinkle into the mix but it should be negotiable. Also, I wouldn't use a TH200 tranny. First off I don't think a Toyota t-case will bolt up to it. Second, I wouldn't think it up to the task as far as strength. Now, if you meant a 700R4, then I say go for it as long as it isn't one of the first couple years for that tranny, they had well-documented issues.
__________________
Dave
'84 XCab, blown 283 V8, SM420, dual cases, etc. -For Sale
'01 Subaru Outback
toy283 is offline
Old 01-09-2008, 04:20 PM   #4 (permalink)
That turbo'd 3.0 looks like a clean install. Don't think I would turbocharge my 22re though, I'd rather use the 4.3.
yeah I've got other options as far as trannies go, I've got a turbo 400 and a 700. Folks build 200's up for GN drag strip abuse but the adapter would be an issue...
Old 01-09-2008, 11:03 PM   #5 (permalink)
stormin94's Avatar
If you can, go the the Turbo400. I think the GN motor is a killer idea, and if I had time/money/knowledge/another car to drive in the mean time, I'd do it.
__________________
1994 Toyota 4Runner SR5 4X4
208,000 miles and counting
3.0 V6, 5 speed
14/19 MPG city/hwy(before 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 01-09-2008, 11:08 PM   #6 (permalink)
CJM
CJM's Avatar
Totally possible, but I wold use a different trans.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 01-25-2008, 09:05 PM   #7 (permalink)
Well it looks like I'm throwing a stock engine in it to drive for now so other future plans can get underway BUT, I've been calling around and have found the best route for this, so I'm going to start gathering parts for the swap.
The Grand National metric 200 is built alot stouter than a normal one and is capable of being bullet-proof. However, it does not have a removable tail housing/shaft etc. I'm using a 700R4 with an Advance Adapters adapter to the stock T-case. Bowtie Overdrives sells a harness adapter for BOP's to the 700.
So, all the hard stuff is figured out, and the only other hard part is cramming the radiator and intercooler into the engine bay but it's possible, with some cutting. Sweet
Old 01-26-2008, 12:22 AM   #8 (permalink)
RobD's Avatar
Sounds like you're going to have a whole bunch of power. Are you sure the rest of your running gear is up to it? How long until the rear diff goes with that much more juice?
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Mendocino National Forest 2/09 JoKEpLaYeR Trip-Trail Reports & Photos 9 02-12-2007 03:33 AM
Wheeling in Chippewa National Forest, MN? slosurfer Off Road Trip Planning, Expeditions, & Trips 0 06-07-2006 10:54 PM
Stop the National Park Give-Away! midiwall Off Topic Talk 3 10-06-2005 06:39 PM
Pondering about border/national security arjan Off Topic Talk 8 09-23-2004 05:32 PM
National Do Not Call Registry va97runner Off Topic Talk 4 06-28-2003 10:24 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
