YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-11-2008, 04:06 PM   #1 (permalink)
GM L67 into a 92 4X4
I have a 92 Yota p/u with a TIRED 3.0 and 5 speed. It is a 4X4 X-Cab.
The GM L67 is an OBDII based 3800 cc supercharged engine. Stock it makes 240 hp and 280 ft lbs of torque. This engine should be in the 275 and 325 range, as it has had a bit of work done to it. I am an accomplished fabricator with access to a full machine shop, so I can make it work, but have never done a swap of this nature and could use some guidance.
Possible issues that I already have a solution for...
I have checked on a clutch with a toy hub and 10.5" GM disk, that is not an issue.
Motor mounts are not an issue, as I said, I am a fabricator.
Have a complete L67 wiring harness and computer, along with the ability to custom tune the computer for the L67.
Will have to fab a 180* 4" horseshoe to bolt the throttlebody onto the blower, as the blower is for a FWD car, and the inlet is at the rear.
Already have an electric fan on the truck, and the GM comp will control it.
Now for the problems that I need an answer for...
Although the 3800 SII GM engines are a 90* V6 they have the 60* V6 bellhousing pattern which makes them incompatible with the 4.3 V6 bellhousings on the market. I think I can make a bellhousing (Machined and fabricated steel, not cast aluminum or formed steel.) , but am wondering if anyone else on here has ever done it and if they have any tips.
Gauges, are the Toy gauges run by the ecm or directly off of the sending units? IE Tach, speedo, oil press, temp. Fuel and voltage are direct read gauges, so I am not concerned with them.
If you have any feedback, suggestions, see any potential problems that I am not seeing, etc, LMK!!! Thanks in advance, Ben H.
Nashvegas Yota is offline
Sponsored Links
To remove this ad, register today!
Old 06-12-2008, 10:27 AM   #2 (permalink)
Kiwipushrod's Avatar
Hey Nashvegas,
I did an L36 on a R150 Toy 5sp, a few months ago, and could not be happier with the results.
Heres a link to My thread over at Pirate 4x4; http://www.pirate4x4.com/forum/showt...highlight=3800
I also have a thread here, but the Pirate thread has much more detail, as there didnt seem to be much interest about a domestic swap, on Yotatech.
Thanks, Kiwi
Kiwipushrod is offline
Old 06-12-2008, 01:28 PM   #3 (permalink)
Thanks Kiwi!!! That is a tremendous help!!!
Old 06-12-2008, 03:08 PM   #4 (permalink)
Hey Nash,
I'm doing an L67 right now, if You use an R154 5sp. from a Supra, You should'nt need the Novak adapter ($300 savings) if You can make a 3/16" sandwich plate, to fit between, the GM 2.8 bell house/large Aisin front trans case bolt pattern. Same pattern on all R series manual trans.
The R154 inputshaft is about 29mm longer than the R150, it also has a .73, 5th gear, so You can keep Your existing diff gears, and end up with about 2000 rpm cruise.
I also would not do any mods to the stock motor, untill You have it running exactly correct......and B.T.W. the official L67 hp rating, is very conservative, it's closer to 300hp @crank, stock... I know first hand. You will be able to Smoke...all the TRD 5.7's You want, S/C 3.4's will be boring, and No One will ever expect You to come up from behind. You will also need a rear locked diff. All this, and still get between 24-30 mpg, with 32" tires.. if You can lay off it.
Pic's of intake tube?
Thanks, Kiwi
Old 06-12-2008, 05:23 PM   #5 (permalink)
Don't have the intake tube built yet.... I am also considering getting a Holden Gen IV M90 housing that they used on the L67 powered Commodores. You can pick up a housing for around $250 or so if you look in the right places. The Gen IV had a 75-80* bend in the inlet side from the factory to clear the firewall. The engine I have for the truck is in my wife's car right now, but we will be buying her another ride in the next couple of months as long as I can get another travel job or two by then. (I am a traveling iron worker.) It already has a ported M90, 3.4" pulley, 72mm throttle body, LT1 MAF, and a few other goodies.
I will probably end up making an adaptor myself instead of buying the Novak. I did not even think about a Camaro B-Housing working.... Thank God for the interweb!!!
Old 06-12-2008, 07:13 PM   #6 (permalink)
Hey Nash,
Is this the style housing, Your looking at?
http://www.yotatech.com/attachment.p...d=12133218 29
I cant seem to get My hands on one.
Anyway, I thought I was the only idiot to see the opportunitys of this swap (in the US), well, now I guess there are at least 2 .......You'll absolutely love it.
Thanks, Kiwi
Old 06-13-2008, 04:01 PM   #7 (permalink)
Yup thats it!!! I want one NOW NOW NOW NOW NOW!!!!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Toyota's for Parts or Complete 85 Truck 4x4, 88 4 Runner, 1993 Truck 4x4, 81 P/U 4x4 jbm715 Vehicles - Trailers (Complete) 23 04-13-2008 06:45 PM
for sale:2002 chevy duramax 2500 4x4 crew cab 4x4 NG Crawler Vehicles - Trailers (Complete) 10 01-27-2008 11:08 PM
will 04 Tacoma 4x4, stock 16" wheel---fit 97 4x4 with no problems? squarerpeg 95.5-2004 Tacomas & 96-2002 4Runners 1 07-10-2007 11:09 PM
Ford Ranger 4x4 height VS Tacoma Sr5 4x4 tacoma728 General Vehicle Related Topics (Non Year Related) 30 01-21-2007 08:02 AM
1990 toyota pickup 4x4 ex cab 4X4 WONT ENGAGE wastedracing 86-95 Trucks & 4Runners 1 11-16-2006 07:38 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
