ever replaced a rod bearing in the vehicle? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-14-2009, 03:15 PM   #1 (permalink)
conman's Avatar
I have a spun bearing I believe and I dont have a way to get the engine completely out of my 86 4runner., can it be done in the truck?
conman is offline
Old 04-16-2009, 06:53 PM   #2 (permalink)
conman's Avatar
well , I guess not.....lol
anyway, I pulled the bolts out of the oil pan and without jacking up the motor and removing the motor mounts, no way to get the pan out of the way to even see the crank journals or rods.
so, with that said, I ordered a complete motor rebuild kit and started removing everything I need to pull the motor.
conman is offline
Old 04-17-2009, 11:24 AM   #3 (permalink)
RevNL's Avatar
I've never tried on a Toyota. Sometimes you can unbolt the mounts and jack the engine up enough to pull the pan. Sometimes it is easier with the crankshaft in a certain position.
Either way, once a bearing is spun, the crank needs to be resurfaced. Time to buy/rent/borrow an engine crane.
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift
RevNL is offline
Old 04-17-2009, 11:38 AM   #4 (permalink)
TOYOTA 1's Avatar
Ive done it twice (91 truck and a 86 4runner). though i changed them out at the first sign of noise(no knocking, just a slight rattle). if you catch it quick enough it should be fine, but if its knocking, then its more than likely time for a crank grind and some over sized bearings.
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 04-17-2009, 12:23 PM   #5 (permalink)
algranger's Avatar
YEah you can replace them in the truck its easy but if you have a spun bearing, new bearings wont fix it your crank is probly scored up and needs to be turned and i'm guessing the rod is scored too
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 04-17-2009, 03:24 PM   #6 (permalink)
conman's Avatar
What....lol,
this is a TOYOTA forum......just kidding...
conman is offline
Old 04-17-2009, 03:26 PM   #7 (permalink)
conman's Avatar
Quote:
yeah, I know....... It was just wishful hinking. and it is knocking after it warms up so I just said screw it and am going to rebuild the whole thing.
I borrowed a motor lift and stand so at least I wont have to do it on the ground.
conman is offline
Tags
02, 22re, bearing, crankshaft, easy, noises, repair, rod, scored, spun, tacoma
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
rod end bearing tricksht Offroad Tech 3 01-30-2009 01:37 PM
2.7 rod bearing 86toysr5 General Vehicle Related Topics (Non Year Related) 0 04-17-2008 03:39 PM
89 rod bearing jx7608 86-95 Trucks & 4Runners 3 03-31-2008 09:42 AM
Need a Piston/Rod/Rod bearing, 3VZE in CO engineerjoe The Classifieds GraveYard 6 06-27-2007 09:21 AM
Help! Bearing replaced and the noise is STILL THERE! Del Maintenance & Repair Archives 6 07-01-2005 09:38 AM
2009 InternetBrands, Inc.
