YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-25-2008, 03:32 AM   #1 (permalink)
cnctony's Avatar
Engine swap/ rebuild nightmare. Help...
Ok I bought my first toyota 4runner. This is where the nightmare starts. I have put so much money into this thing I can't stop for fear of loosing it all.
I started off by replacing tires, tie rods, calipers, rotors, pitman arm, drive shaft, battery, cat and exhaust pipe and alternator and a 60.00 modulator valve to pass emmissions. Then at the inspection station when runing the engine the heads blew. coolant everywhere. I sent the heads out to have rebuilt and reinstalled. Ran for about 500 miles then on the innerstate at 65mph it died and coolant was everywhere. I thought the head gasket went again however when I finally got it home pulled engine, started taking apart I found the timing belt broke and a small hose broke. OK I had the engine apart so I decided to rebuild the whole engine. My first thought was to do an engine swap however in Harris county I would not be able to get it inspected because of rules.
I didn't have time to work on engine but a friend of mine said he would do it for a laptop computer. He started and then he changed jobs and didn't want to finish. So I got my motor back in pieces. He broke several parts taking apart. I spent Sunday at the junk yard getting all the parts I needed. I am ready to finish putting this thing together.
ON to my questions.
I sent the block out, cyl 20 over and had crank checked and polished.
I have installed new, main berings, pistons and had the heads serviced. I have engine back together however since I didnt take apart I have a couple of brackets that I have no clue where they go.
Also the new gasket kit came with 2 thick cork style oil pan gaskets. Do I put them in without sealant?
cnctony is offline
Sponsored Links
To remove this ad, register today!
Old 08-27-2008, 05:21 AM   #2 (permalink)
cnctony's Avatar
Where do these part belong on the engine?
I talked to Toyo mechanic he said not to use gaskets on oil pan, just 1/8in bead of silicone. If I can figure out how to insert a pic can some one tell me where these 2 brackets go and the o-rings that were in the kit go?
brackets and o-rings
http://yotatech.com/gallery/showphot...ll&limit=last1
engine
cnctony is offline
Old 08-27-2008, 05:31 AM   #3 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Welcome to Yotatech.
You should have checked here before you bought that 2nd Gen with a 3.0
I'd suggest purchasing a FSM, fixing your truck and then driving over to your "friend's" house and kicking his arse.
Good Luck.
waskillywabbit is offline
Old 08-27-2008, 06:36 AM   #4 (permalink)
zlathim's Avatar
Quote:
Originally Posted by cnctony View Post
ON to my questions.
There are two brackets with a total of four holes each that attach one on either side at the bottom rear of the engine block. They support the bottom of the tranny belhousing. There are also a couple of brackets for the power steering, one of them is curved kinda funky that seems to make people scratch their heads.
The two gaskets are for the oil pan and the windage tray that is sandwiched between the oil pan and the block. I used the FIPG and chucked the two gaskets into the trash can. I used a 1/4 or so bead of sealant on both the windage tray and the oil pan surface. If you do decide to use the gaskets, don't apply sealant to them.
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks?
Idiocracy (edited for family friendly viewing)
zlathim is offline
Old 08-29-2008, 09:14 AM   #5 (permalink)
76ANTHONY's Avatar
DONTTTTTT USE THE OILPAN GASKETS, you'll find that the oilpan bolts will all be too short, use a good sealant and it will not leak. i had to pull my gasket off and seal her up and throw away the gaskets, what a pita...
76ANTHONY is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
TC's nightmare/rustbucket A-ARM swap.... Lysmachia 86-95 Trucks & 4Runners 25 05-24-2008 09:41 PM
4.3 swap or rebuild 3slow prior185 86-95 Trucks & 4Runners 4 05-05-2008 11:59 PM
1991 4Runner body swap or engine/tranny swap? 91slowrunner 86-95 Trucks & 4Runners 2 05-21-2007 10:11 PM
92 toy engine swap 89 rebuild rose 86-95 Trucks & 4Runners 34 01-04-2006 06:08 PM
rebuild or swap? playboy 95.5-2004 Tacomas & 96-2002 4Runners 12 01-04-2004 05:01 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
