YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-15-2008, 05:56 AM   #1 (permalink)
canuckyotafan's Avatar
Send a message via MSN to canuckyotafan
engine swap question
I am thinking about doing an engine swap on my 1990 4runner. Have access to a solid axel out of a toyo. My question is if i put a chev350 in it, should i go to dana's or just build up the toyo axels?
I am going to use trail-gear 5 inch lift. Does anyone have any other suggestions for other lifts? Preferably a 6 inch one?
thanx richie
canuckyotafan is offline
Sponsored Links
To remove this ad, register today!
Old 01-24-2008, 11:11 AM   #2 (permalink)
cnctony's Avatar
I am wanting to replace my blown 3VZE with a tricked chevy 302, transmission and rear end. I have a lot of fabbing to do and am wondering what am I going to get myself into........ ?
cnctony is offline
Old 01-29-2008, 10:43 PM   #3 (permalink)
rockdawg84's Avatar
thanx richie
Richie,
I believe that unless your going to go to Dana 60's or Corp 14 you should stay with the yota axles. They are plenty strong based upon your driving style. if you blow them up go to a corp 14 in the rear and then a Dana 60 in the front.
good luck. as for lift go with the trail gear 5inch springs and then use 2inch longer shackles which will net 6inches of lift.
Quote:
First, Welcome.
Now search and read my friend. not flaming you but it is the best way to learn what other have gone through. Also be sure to start your own thread so you don't Hijack someone else's question. Good luck.
__________________
84 Runner streched and pounded but still crawlin
95 Runner about to be a fire Breather. I hope
rockdawg84 is offline
Old 02-04-2008, 05:51 AM   #4 (permalink)
cnc u are getting into quite the job. if u know how to weld and use steel tools u should be fine. u ever replaced an engine for the same one before? best thing to do is take pictures of everything u do. i mean everything, even to the effect that u might be taking to many. they are the best way to remember what u did and have done. this way u wont have to go back through and tighten stuff twice. good luck. look forward to see what u do.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Engine swap question lukeman970 86-95 Trucks & 4Runners 3 08-15-2007 03:51 PM
question about engine swap 4x4yoda 84-85 Trucks & 4Runners 0 12-17-2006 04:05 PM
engine swap question Eddie Monster 95.5-2004 Tacomas & 96-2002 4Runners 10 03-27-2005 09:19 AM
engine swap question Extremesolo 95.5-2004 Tacomas & 96-2002 4Runners 0 01-23-2004 12:46 PM
Another engine swap question- HaveBlue 95.5-2004 Tacomas & 96-2002 4Runners 4 05-12-2003 08:29 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
