Engine Swaps Swapping an engine in your Toy, here is where to learn how
Engine Swap Problem
Old 05-19-2016, 05:11 PM
Den01Gen3's Avatar
Engine Swap Problem
1st time engine swap. Drove 01Runner into garage. Vehicle was left in neutral w/ E brake on. Engine cranked by hand no problem. Removed old engine. Replaced TB & water pump on donor vehicle engine cranked by hand no problem. Installed donor engine into runner. Turned crank to align machined key slots in Torque Convert and slid into postion. Tightened all bolts on tranny. Put all parts back together. Tried to crank by hand and won't budge. Check to see if its in neutral
still won't turn. I can push the car in neutral. I am lost as to why it won't turn. Any ideas appreciated.
crjosh97
06-25-2016 03:10 AM
nickwalsh
05-17-2016 05:23 AM
Bad Brad
05-16-2016 11:48 PM
bgbailey3597
05-13-2016 09:02 PM
jjrbus
05-13-2016 09:18 AM
Quick Reply: Engine Swap Problem
