| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Engine Swap. Which is better? Gas or Diesel
#2 (permalink) |
What state are you in? That might have a lot to do with what you can do with your swap.
I was looking at both of these but I want to keep my 5 speed and that's the kicker on mine. I will most likely be putting a aluminium VORTEC 5300 in cause it's cheap backed by a NV3500. Gives me about 300/300 and will do just fine gas mileage wise. I also don't think it'll cost more than 1500 or 2000 max. The engine and wiring should cost about 3-400 and about the same for the tranny. Then it's no goofy combinations. If you want an auto it's even easier cause it's a lot more common behind that motor. Anyways, bring on the flaming. Haha
__________________
If it has tits or tires it'll give you problems. 98 4runner - SR5, 4x4, 5 speed The Probe, CJ5, G20 and Porsche are all sold. Right now everythings a 4x4 or 6x6. MRAPs, 916s, HMMWV, FMTVs and anything else with amror. |
#3 (permalink) |
i think the diesel would be awesome and fun
#4 (permalink) | |
Quote:
You can keep a 5 speed with both Toyota options, just takes a custom bell housing. I've seen them for sale on some Aussie websites. Not cheap, but still reasonable if you need to keep a manual |
#5 (permalink) |
diesel is my 2cents. They're just cool and gas is only eventually going to get more expensive.
#6 (permalink) |
if you have the $, i would go diesel.
__________________
TRAIL GEAR's CUSTOMER SERVICE IS TERRIBLE MORE LIKE A HEADACHE OR PAIN IN THE A$$ THAN A SERVICE! -1980 toyota 4x4 - 235/85/16 bfg M/T tires, 03 tacoma wheels, onboard air, trd camshaft, 18" e-fan, weber 32/36 carb, 4.88 yukons, lockright in rear, etc -94 xcab SAS, arb/lockright, 5.29s, 4" lift, etc... Yota tech gallary- http://yotatech.com/gallery/showgall...ser=15173&sl=i <---yes, that is victory blood! |
#7 (permalink) |
If you actually DO either, please post a s&*t ton of pics/info.
__________________
92 4wd xcab pickup, 22re, 5 speed |
#8 (permalink) |
I am trying to screw Citibank by maxing out my card and settling for pennies on the dollar, so in that respect, a diesel is the way to go!
The ability to run alternative bio fuels that are almost free and emit lower emissions is definitely a plus. Several people have passed emissions in AZ and CA with the 1KZ too. Here's a great forum on the diesel swap: http://www.toyotadiesel.com/forums/ |
#9 (permalink) |
Horribly underpowered 5vz? Your crazy. Ever driven a 3vz or 22re? Probably not.
I bet that diesel will have less seat of the pants power than a 5vz.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#10 (permalink) |
Well just for a reference, supercharging your 5vz and getting the necessary goodies to make it run well will run you about $3000-$3500 depending on how much you get the charger for. That will give you about 300-320hp at the crank, more than the stock 1UZ.
So the diesel swap costs about twice as much, and the 1uz swap will probably cost about the same if not more when everything is said and done. Although the supercharger's price tag up front can be hard to swallow, it's actually pretty hard to beat on a hp/$ basis.
__________________
Brian 1998 4Runner SR5 |
#11 (permalink) | ||
Quote:
I agree, the diesel probably wouldn't blow my mind with the power increase, but cheap fuel potential is tempting. Quote:
I also don't trust the 5VZ under higher boost levels. It comes from the era of Toyota engines with lighter weight bottom ends with spindly rods that cannot take the added stress. Well documented with rod failures on boosted 5VZs, later 1-2-and 3UZs, 1MZs, etc. I've also never seen a 4Runner or Tacoma with that sort of power output from the supercharger. Maybe ~280HP at the crank, but the underrated OBD-II 1UZ certainly makes that much, too, and is far more reliable to boot. |
#12 (permalink) | ||||
Quote:
Quote:
Quote:
Quote:
In addition, the 5vz fuel system is undersized for the supercharger, causing lean conditions and possible detonation after a full-throttle run (which can cause the rod failures you are describing). You also get better power and lower EGT's if you run an AFR of about 12.0:1 in boost, rather than 14.7:1 which is what the stock ECU will aim for. You should keep in mind that a 1UZ is a rare modification for a reason (I've only seen a handful of attempted 1UZ swaps, and only two with confirmed writeups of them running properly, both in 2nd gens). How many supercharged 3.4's are out there, tens of thousands? Overall, it sounds to me like you're going to want to go the 1UZ route, which is fine. Make sure to get a donor car with a working tranny if you can, and cannibalize its electrical harness to adapt it into your 4Runner.
__________________
#13 (permalink) | |
Quote:
__________________
#14 (permalink) |
The more I look into the 1KZ the better it sounds.
With a chip alone you can get nearly 300 ft/lbs of torque. Add a simple manual boost controller or a Greddy Profec and get ~13 psi on the stock turbo. A bigger "CT20b" or CT26 bolts right in and can net even more power for not a lot of money. A better down pipe and 3" exhaust will kick even more ass. Even using the 5VZ airbox with a True Flow filter would net gains over the JDM intake. With tuning and some mods, this could easily out perform a supercharged 5VZ in the torque department, with far more control over the power output. I'm sure 170 BHP and 300+ ft/lbs is easily within reach. Only bad thing is it costs a nut and a sack. However, the sustainability factor of diesel really sells me. It is the fuel of the future. You can run B20 no problem, diesel itself is getting cheaper and is a more powerful fuel, and again, WVO is always a viable option. The 20 deep line of fat asses I see everyday in the drive thru of a new lame ass Jack In The Box down the street assures me that grease will always be readily available in America. I figure a 1KZ setup to make awesome of power would come in around $10K, but with less headaches than a $6K 1UZ swap that would leave me with a real nice, engine-less LS400 to try and get rid of. |
#15 (permalink) |
i own both the 1kzte and the 2lte surfs,
the 1kz is a good motor and has heaps of usable torque, load of power from 1200rpm to about 3400rpm, power drops off after that in 2wd it will spin the rear wheels with 31 10.5 r15 on tarmac no problems will eat 3vz and 22r for breakfast, 5vz are slower than 1kz i WOULD NOT turn up the boost on these motors more than 2psi over stock unless you have reset the pump and injectors to suit or you will get cylinder bore wear and it causes a knock in the motor that sounds like a big end has gone, (seen it many times) a good inter-cooler and fuel increase will give you 145hp no problems and good torque gains (stock), the bottom end is virtual indestructible, large, wide bearings, with hardened crank, good strong rods early short valve models had problems with the head cracking, this design flaw was fixed back in 1994-95, with the new long valve head, use a Manuel trans radiator because of automatic trans cooler blocks off most of the lower radiator outlet to the engine, make sure that you replace the viscous coupling silicon fluid in the fan hub, the main reason for overheating issues when towing or laboring the motor. due to worn silicon. this is all mixed running around early 90's 1kz done about 12-15L per 100k, (18usmpg - 15usmpg) (23-18 imperial mpg) ( newer than 1999 1kz were returning 10L per 100k or (usmpg 23.5)(28mpg imperial) in hiluxs, 11L per 100km (usmpg 21)(25mpg imperial) in the prado (landcruiser) Last edited by MUNJUE; 10-07-2009 at 03:27 AM. |
#16 (permalink) | |
Quote:
I think I'm going to scrap the mechanical fan altogether no matter what swap I go with. There's some Derale and BeCool fans that I think would work fine, or the Taurus fan in a pinch. Would you happen to know if any aftermarket tuning box (Steinbauer, Dtronic, etc.) are user programmable for fuel maps? I'm having a hard time getting good info on these things. |
#17 (permalink) | |
Quote:
Where do you get almost free diesel fuel?? TJMWO, gNARLS. Last edited by Gnarly4X; 10-08-2009 at 01:38 PM. |
#18 (permalink) |
I swapped my 3vz to a 1kz-te. It has good power, I have a 3" intake/exhaust, intercooler, boost control, and turned up 'fuel screw'. I'm running 255/85/16 (34"?) tires and 3.73 gears and get 27mpg on the highway and 22-23 around town. It is not an easy swap as the diesel's were rhd and the wiring harness needs to be lengthened/modified. Manual transmissions are not easy to get because of the bell housing issue (other than that you could use R series transmissions). Grease for bio diesel is pretty hard to get, all restaurants are under contract and you really only want grease from chinese places. The engine mounts are not the same and will have to be fabricated, the oil filters have to be special ordered and cheapest is $10 per. Aftermarket tuning boxes are a rip off for these motors as diesels don't have an air/fuel ratio to worry about (other than too much fuel will burn your motor up, a pyrometer is a must!) and the ECU is pretty primitive and can be 'fooled' by changing a few resistance values. Stock these motors do well from 1800rpm and up, I don't think it pulls well from 1200rpm. (I'm trying to change that by changing a resistor). I also put in a 4 core V8 swap radiator and did a mod to make my temp gauge actually work (factory temp gauges don't move even after the water has heated up 20-30*c!) to keep an even keel on the temps. When I moved I pulled a tandem axle 6x12 u-haul trailer (combined wt of truck and trailer was just under 9500lbs) and managed 17mpg and 60mph. The swap was pricey, but worth it. However I had a 3vz that had just blown another head gasket....I don't think I would have swapped this in place of a working 5vz, of which I have driven a few of. So there is a couple of years of experience with a 1kz in summary for you, good luck
#19 (permalink) |
i have a 2lte and might not be as good as91 diesel bigger but i love it to bits!!
i dont have a pyro but i never drive it hard.. when i get a 2.5 exhaust im putting one in though!! i have driven it for a few years and its just amazing! it doesnt win races as its a DIESEL and its a TOYOTA but you can feel the power and the turbo helps it go once you get over the lag... im not going back to a gas toyota im always gonna look for diesel now.. might even pop ,my 2lte in my suzuki samurai and replace it with a 1kz-te when i find a bucket of cash
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ |
#20 (permalink) | ||||||
Quote:
My last engine swap was a B16 into a Civic VX. Came in under $2300 with engine, LSD trans, Exedy clutch, Honda timing belt kit and even a new O2 sensor. It's all about how frugal and resourceful you are at finding parts! Quote:
I would probably get the harness made for me. After the 3 days I spent doing a brand new harness for my HID headlights, fogs and roof lights and the associated relays, I'm done with wiring! I've heard manuals are tough to source, but I would just stick with an auto anyway. Not optimal, but easy and A340s can hold way more power than the R150 with some Raybestos clutch packs should I need to rebuild it down the road. Quote:
Quote:
I would use an Amsoil filter anyway, number Ea015. They last 17,500 miles on gas engines, longer on diesels, especially when the 1KZ uses 7 qts of oil! Quote:
Can't believe these engines have been around for 15+ years but no one has really made inroads into a simple, cheap tuning box. Quote:
I certainly appreciated your review, though. I love to hear feedback on what others think of this swap. How much was yours all said and done? |
| Tags |
| 1kzte, 3vz, 5vz, aluminium, automatic, chinese, diesel, engine, kit, ls400, motor, potential, rebuild, swap, swapped, swaps, toyota |
