efi mtor to carb setup swap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-02-2009, 07:39 AM   #1 (permalink)
sktrspud's Avatar
hey guys there has been like a million different carb to efi threads but i have kind of a unique one..... i have an 83 p/u that was carbed and the motor blew, so i picked up an efi motor and want to know if i can just switch over the carb intake onto the efi motor, i know i need to switch out the dist. for my 22r one cuz of the vacuum advance but other than that i need some advice!!!
sktrspud is offline
Old 05-02-2009, 08:35 AM   #2 (permalink)
Plumbrbob's Avatar
yea switch out the intake for a carb intake, block off the egr crap, and put in a dizzy with vaccuum advance you should be set but i may be missing somthing. BTW the 83 intake wont match up to the 85-95 head.
If you cant find the parts I have what you need for sale but your a little far from me.
set you up with an intake and anything else intake realated you need and a dizzy with vaccum advanced PM me if you need me
__________________
79 YotA ThinG
Mods: http://www.yotatech.com/blogs/plumbr...list-mods.html
Plumbrbob is offline
Old 05-02-2009, 08:36 AM   #3 (permalink)
Plumbrbob's Avatar
oh yea have fun with the alternator set up best to jsut switch out the entire bracket from you old alternator and use you your old alternator so the pins stay the same
__________________
79 YotA ThinG
Old 05-03-2009, 03:43 PM   #4 (permalink)
sktrspud's Avatar
alright, so i pulled the old motor out and put the new one up to the transmission, and bolted the motor mounts down and the exhaust up to the block, as well as put the dizzy from my 83 in, and the fuel pump, and ran the vacuum line assembly thingy on the new block....so technically.. all i need to do is put the starter in, get a new intake that fits this year model head, cuz like you said the coolant port is different.... and i should be ready to rock and roll right?
sktrspud is offline
Old 05-03-2009, 03:44 PM   #5 (permalink)
sktrspud's Avatar
oh and i havent switch over the alternators, but thanks for that heads up, i probably would have hooked every thing up before i realized it lol
sktrspud is offline
Old 06-08-2009, 11:11 AM   #6 (permalink)
sktrspud's Avatar
alright finally got it switched over completly... so far this is what i have found..... you need to use the dizzy with a vacuum advance, a mechanically fuel pump that should mount into the hole covered by a block plate on your fi head, then the thing that a missed for the longest time is you have to use a lobe that comes on the carbed motors that bolts onto the cam shaft to pump the fuel pump, there shoudl already be a washer on the fi cam that is the same width of that lobe so you just remove the washer and bolt the dizzy gear and the lobe back up, you need to use the 22r intake with carb, and the exhaust manifold off a carb, or just build or buy headers for it. the trannsmision bolts right up, clutch everything is the same.... that should just about help anyone out that had the same problems i did lol anything else just pm me
sktrspud is offline
Old 06-08-2009, 11:14 AM   #7 (permalink)
ocdropzone's Avatar
a lot of people would have gone the other way around carb to EFI...
but some good info here...
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is online now
Old 06-08-2009, 11:24 AM   #8 (permalink)
sktrspud's Avatar
idk, i plan on running pane so the carb does the trick lol but there is a million threads on converting to efi from carb, i thought i would throw a thread in there going the other way, i found out that the old fiftys chevy 1 barrel carbs work amazing on a 22r, they give it like 3 more fmf or whatever that abreviation is lol and they are so much simpler
sktrspud is offline
Old 06-24-2009, 04:55 PM   #9 (permalink)
yoterr's Avatar
you might have to have the cam escentric for the fuel pump if your motor doesent have it, wich you should be able to grab it off your old one, its just a round off center plate that pushes on the fuel pump arm, sits right behind the cam bolt
__________________
new to me 86' toy on 35" procomp mud terrains, with a 4" lift and 3" body and palm fron camo for now...
04' Dodge 2500 4x4 QC hemi leveled, home made CAI and flowmaster exhaust
yoterr is offline
Tags
carb, carburetor, dizzy, efi, set, setup, swap, switch, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
carb efi swap myyota89 86-95 Trucks & 4Runners 11 11-14-2009 12:53 PM
EFI to carb swap savagesloth General Electrical & Lighting Related Topics 7 02-07-2009 05:32 PM
EFI to carb swap slayyerr 86-95 Trucks & 4Runners 27 10-28-2008 06:01 PM
How hard is it to change from efi to carb setup? YOTAKIMMER 86-95 Trucks & 4Runners 4 01-17-2007 10:20 AM
22R Carb to EFI Swap AKennedy87 95.5-2004 Tacomas & 96-2002 4Runners 20 07-01-2004 09:21 PM
2009 InternetBrands, Inc.
