YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-15-2008, 03:43 PM   #1 (permalink)
Toyin's Avatar
Any succesfull 4.3/700r4/Dana 300's??
85 toyota
I have the 4.3/700r4 in and I just bought the AA kit for the 300 to 700r4.
The driveshaft up front has to be pretty small od due to the 700r4 pan. I can't deicde to stick with a 208 adapter to mate the 300 or the AA kit that includes the new 300 shaft.
ANy pics or build threads in here with the drive train setup I can look over for pointers?
I have a guy commited ot helping me build the skids/supports in a couple of weeks and I want to be prepared.
Thank you
Toyin is offline
Sponsored Links
To remove this ad, register today!
Old 05-18-2008, 12:03 PM   #2 (permalink)
cujeeprs's Avatar
I have the Vortec 4.3, 700R4, D300 combo in my CJ-7. I did the swap about 8 years ago using a Novak 700R4 to D300 adapter. With that kit you replace the D300 input shaft to match the 700R4 output shaft. I like it since I can swap the trans for any 4wd 700R4. I also had a close fit on the front shaft, but, so far I've had no problems with it. My biggest problem has been motor mounts, and I'm fabbing a new set now, that will hopefully last. Good Luck!
__________________
Scott
1994 Extra Cab, loaded, V6, 4" Superlift, 33x12.50's on 15x10 aluminum, 204,000 miles and counting, daily driver.
2002 4Runner Sport, Toytec/OME Coil lift without top spacer, Diff Drop, 285/75/16 BFG AT on Stock Sport Wheels, Mall Crawler GONE! The ex-wife kept it after our split!
1983 CJ-7, 4" BDS lift, Lock-Rite F&R, 4.3 Vortec V-6, 700R-4, Warn Full Float Rear, Warn Front Shafts, Rock Hard 4x4 cage, lots of other junk....
cujeeprs is offline
Old 08-15-2008, 07:12 PM   #3 (permalink)
Toyin's Avatar
Do you have any pics of your front DS?
Toyin is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
dana 44? 4x4YOTA Solid Axle Swaps, All Years 7 04-24-2008 04:17 PM
86 4runner d60's, 4.3l, 700r4, bobbed, exod intheworks Vehicles - Trailers (Complete) 7 09-12-2007 08:20 AM
speedo cable for83 w/ 700r4,208 ganemeade The Fab Shop 0 11-24-2006 01:11 AM
What should I do with this dana 35? Tacoma Dude General Vehicle Related Topics (Non Year Related) 10 03-25-2006 04:16 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
