Engine Swaps Swapping an engine in your Toy, here is where to learn how
91 4runner with 5vz-fe swap.
Old 11-28-2013, 08:46 AM
CodyRunner's Avatar
So I have a 91 runner and it has a 98 5vz in it. On the highway I run about 75-80mph at about 3100rpm. Is that normal?
Old 12-05-2013, 07:01 AM
alfio's Avatar
depends on the transmission and rear axle gearing - what are the specs on those?
Old 12-05-2013, 09:49 AM
CodyRunner's Avatar
Factory 4.88 gears and I'm not sure about the tranny.
Old 12-05-2013, 10:07 AM
alfio's Avatar
stick or auto?
Old 12-05-2013, 10:24 AM
92yota92's Avatar
Wether you used a pre or post 95 trans the gear rations shoudl be the same.
5th gear ratio in either a new or old r150 is .83 and that's a little short. The At is closer to a .7 ratio in 4th so if it's standard it doesn't sound too far off it's its an auto it might be a bit high.
Tire size can be a factor.
Old 12-05-2013, 04:22 PM
SacRunner's Avatar
What size tires?
I was somewhere around there with 31's and 4.56, but with the 33's I have now (and the same 4.56's), the engine speed is a little lower.
And just so you know, the engine speed (rpm) for a given wheel speed (mph) has nothing to do with the motor, it's all about the various gear ratios between the transmission, axle, and tire diameter.
icentropy
09-16-2020 02:47 PM
snosurfer
3.4 Swaps
03-29-2016 11:29 AM
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
Quick Reply: 91 4runner with 5vz-fe swap.
