YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-16-2008, 12:28 PM   #1 (permalink)
oldgold3vze's Avatar
89 22re (pickup) in a 88 4runner, intake differences
I'm in the process of swapping a 22re motor from a 1989 pickup into an 88 4Runner, but it looks like the intake is a little different. I'd like to use the entire motor, including the intake, from the 89, if possible, because the intake from the 88 is very dirty and full of carbon, but the 89 is pretty clean. Basically what I need to know is do I have to switch the entire intake manifold, or can I just reroute some of these vacuum hoses? The 88 motor has a "0" code on it and the 89 has a "7" both stickers are right near the air intake if that helps. Also, the 88 has a box with a blue plug and 3 vacuum hoses on it and the 89 does not. Thanks for any and all help.
oldgold3vze is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Differences Pickup/Taco IFS nix4x4 86-95 Trucks & 4Runners 3 02-18-2008 07:48 PM
89 4runner lower Intake Manifold (22re) bushinsappony Engine/Tranny/Parts 0 12-09-2007 06:46 PM
85-93 22RE Differences??? timk2915 Newbie Tech Section 1 09-25-2007 08:58 PM
Intake Noise Differences ravencr 95.5-2004 Tacomas & 96-2002 4Runners 0 02-09-2003 04:35 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
