88 4wd to 92 2wd swap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-01-2009, 06:34 AM   #1 (permalink)
Howdy, I had a 92 2wd that the motor went kaput and found one from an 88 4wd. everything looks the same except the oil filter location and pan. The 2wd has some sort of aparatus where the oil filter is on the 4wd model and the 4wd model has a cap over where the filter is on the 2wd model. Oh and the oil pans are different.
Here's my questions Is this a pretty straight forward swapping of the oil pans and oil pump pick up tubes or is it more complicated?
Does it matter if I move the filter locations?
Thanks
George
dufus is offline
Old 05-02-2009, 05:56 AM   #2 (permalink)
Cool site. Thanks to the folks who posted the manuals on line that was a big help. Turns out what I was looking at on the 92 3.0 was an oil cooler. The 88 doesn't have one, so looks like I should be able to move filter locations without any issues and press on
George
dufus is offline
Old 05-06-2009, 03:30 PM   #3 (permalink)
berm84's Avatar
Send a message via AIM to berm84
no it should be fine but i am 100%sure never had a 2wd
__________________
90 pick up 88 gmc 3500 6.2 diesel tow rig
berm84 is offline
Old 05-06-2009, 03:31 PM   #4 (permalink)
berm84's Avatar
not 100% sure
__________________
berm84 is offline
Old 05-06-2009, 05:24 PM   #5 (permalink)
Turns out that there is more difference than you might think. between 88 and 92 and 2 to 4wd the harnesses are different. So I swapped in the 92 harness to find out the injector connectors are different. The oi1 pan is different. The motor mounts aren't the same. The p1ug for the tps different, the gas 1ine connection is different and the exhaust isn't 1ining up and 1ooks 1ike I'11 be cutting it up tomorrow. SO it has been a fun coup1e of days changing and modding
George
dufus is offline
Tags
1985, 2wd, 4wd, swap, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Can I swap a 4wd engine and tranny with a 2wd tranny and engine yota_Pirate 86-95 Trucks & 4Runners 2 04-27-2009 06:30 PM
2wd to 4wd swap. thepaul Newbie Tech Section 3 04-22-2009 12:20 PM
86 2wd to 80 4wd engine/trans swap? 8086 yoda Newbie Tech Section 1 05-05-2007 08:50 AM
2wd to 4wd brake swap desert whomper 95.5-2004 Tacomas & 96-2002 4Runners 1 07-06-2005 12:03 AM
4wd problem/tranny swap/t-case swap wtf squishy321 Offroad Tech 2 04-01-2005 11:41 AM
2009 InternetBrands, Inc.
