Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
6 speed manual swap and t/c??
If someone wanted to drop in a GM LS1 with a 6 speed manual into a 95 V6 4 runner, how would they go about adapting a t/c to the tranny?
Also is there anyone who has installed a V8 and kept their A/C intact? NWOR has some great products that look like they may make the swap easier, has anyone used their looms or mount kits?
__________________
1995 3.SLOW 4X4 AUTO SR5 STOCK AND MORE RELIABLE THAN MY OLD JEEP |
| Sponsored Links |
#2 (permalink) |
I did the same swap in my bosses 844runner and i had to call advanced adapters and have them make me an adapter
__________________
1988sr5v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1988sr5v6 4runner with a 4inch allpro longtravel sas with detroit rear a ls in front and 33s 1985 sr5 4runner 8inch lift 39.5 boggers 529s detroits front and rear and triple transfer cases with a final crawl ratio of 2828to 1(sold) |
#3 (permalink) |
Just use OTT's divorced case adapter. runs about 400 bucks and then run whatever trans you want. just a thought.
__________________
84 Runner streched and pounded but still crawlin 95 Runner about to be a fire Breather. I hope |
#4 (permalink) |
I too was considering the same swap, putting a T-56 behind the LT1 in mine and I was told... "the ouput shaft on the T-56 has a problem with oversized tires and will not last with that low of a gear ratio". I can't remember if it was Downey or Advance Adapters that told me that tho, it was probably 6 years ago, just as an FYI. Good luck to you in your swap.
Zach |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2wd 4 speed manual trans. | hmmwv15 | Engine/Tranny/Parts | 0 | 08-15-2007 09:50 PM |
| 1978 pickup 4 speed to a 5 speed swap? | mackdss | Pre 84 Trucks | 7 | 08-21-2006 08:37 PM |
| 3.4L V6 (5VZ-FE) Swap into my '92 3.0L (3VZ-E)w/ 5 Speed manual tranny | windancer4x4 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-15-2006 11:39 AM |
| For Sale: 98 SR5 V6 5 speed manual | 2maxxx | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 12-09-2004 06:10 PM |
| Automatic tranny to 5 speed manual.... | JaRuEL | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-09-2003 05:49 PM |
