YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-08-2008, 08:05 PM   #1 (permalink)
5M-GE bellhousing
I've found an old low mileage I6 to swap into my desert truck.
I have a R151 trans from a 22re turbo.
Will the 5M-GE bolt to that? or do I need a different bellhousing?
Thanks
HardCharger81 is offline
Sponsored Links
To remove this ad, register today!
Old 09-08-2008, 08:25 PM   #2 (permalink)
Toy-SkiTzo's Avatar
you need the bellhousing from a 5spd non turbo supra with a w58 motor
__________________
86 4runner, TG 3in rears, RUF, 36x12.5 TSL/sx on allied beadlocks, 85 toy axle, FROR crossmember ,rear disc brakes, Detroit front,welded rear, 4.10 gears,dual cases, hysteer,30 spline longs, full exo,pickup gate,
link to my build
Toy-SkiTzo is offline
Old 09-21-2008, 09:24 PM   #3 (permalink)
annoyingrob's Avatar
Or a 7M-GTE bellhousing, and a R154 transmission with the tail housing swapped over from an R150F or R151F.
Or a 7M-GTE bellhousing with a newer R150 with the longer input shaft.
annoyingrob is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What starter? 4.3 with AA bellhousing bcumbie 86-95 Trucks & 4Runners 2 04-29-2008 08:23 AM
22re Bellhousing RD1970 86-95 Trucks & 4Runners 5 12-14-2007 10:39 AM
Flywheel + bellhousing gametom 86-95 Trucks & 4Runners 16 11-12-2007 10:24 PM
4.3 to 5spd bellhousing 95RunnerSR5 Items Wanted 0 06-03-2007 09:41 AM
need bellhousing becks86yota Engine/Tranny/Parts 0 05-03-2007 08:05 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
