YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-15-2008, 10:44 AM   #1 (permalink)
3VZE??? Deal or “NO” Deal ???
Anyone every bought from http://www.toyotacarpart.com?? I’ve found a long block for a deal, $1500.00 for a 3VZE. Even called them and it seems legit. The long block comes with everything except VC, manifolds, cam gears, oil pan, etc…. everything internal is install and torque to specs…. All I need to do is add the external parts from my motor and set timing..(OR) Is it too good to be true…. Any thoughts on this deal…
tyes is online now
Sponsored Links
To remove this ad, register today!
Old 06-15-2008, 10:54 AM   #2 (permalink)
olharleyman's Avatar
Seems that by the time you redo the heads and cams(machine work and parts to rebuild) and everything else your going to be right in the $2500-$3000 range.
For that you can do the 3.4 (not that I am pushing it) but you can get so much more out of the 3.4 power and fuel mileage wise that it might be worth looking into.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
Streached 5.5 gal. tanks
16" Ape Hangers
3" open primary
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 06-15-2008, 05:44 PM   #3 (permalink)
I dont think this setup will cost that much. Since we are just going OEM with no mods..I've research into a 3.4 setup as well. But after research and research, I dont really want to deal with Cali Smog Regulations and so forth. I've deal with that so many times with Hondas / Acuras, I dont want to add Toyota to the list. Like I mention this long block comes complete with everything and all I need to install is just the basic exterior parts of the engine. This will cost me no more than 1500.00 + shipping + 200.00 (misc parts)... And, It will make room for a suspension lift, new pro-comp wheels, 35x12.5 tires, and 5.29 US Gears.. Thats why I'm more leaning on the 3.0 setup than the 3.4.. Thanks for the suggestion... I was actually going for the site I have listed. I've also seen in listed here on yota tech a few times. can anyone input???
tyes is online now
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
DEAL OR NO DEAL..? Totaled Runner Drive train purchase question (not mine thank god) icerunner 95.5-2004 Tacomas & 96-2002 4Runners 3 05-25-2008 10:09 AM
How do you deal with...... wormhole Off Topic Talk 3 10-26-2007 06:46 PM
Good deal on 3vze 3.0? mike92runnerSR5 86-95 Trucks & 4Runners 9 03-30-2007 08:14 PM
is this 3vze a good deal? ByThaBay 95.5-2004 Tacomas & 96-2002 4Runners 3 09-30-2003 09:52 AM
Good Deal...Bad deal? DavidO06 95.5-2004 Tacomas & 96-2002 4Runners 2 10-13-2002 10:11 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
