YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-09-2008, 03:00 PM   #1 (permalink)
Send a message via AIM to jvc971
3vze auto to manual
i just did the 3vze auto to manual trans swap.
all you need is;
clutch bracket
slave cylinder
master clutch cylinder
clutch line
manual tranny
crossmember
shifter sensor from auto tranny
clutch
flywheel
the stock ecu will work fine.
you will have to get the rear driveshaft cut and lenghtened because the auto tranny is 3in longer than the manual one.
jvc971 is offline
Sponsored Links
To remove this ad, register today!
Old 09-09-2008, 03:02 PM   #2 (permalink)
i am having a problem by the slace cylinder is not going far enough and my gears are grinding and my shifter doesnt have the shifter gromet that goes under it.
jvc971 is offline
Old 09-09-2008, 07:12 PM   #3 (permalink)
ok i found out that its not the slave its that there was no tranny fluid in it. i am going to go buy and put some in it tomorrow and see if that made a difference
jvc971 is offline
Old 09-09-2008, 07:42 PM   #4 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
Quote:
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
Pedal assembly too but thats a given. could always make your own too
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 09-10-2008, 12:37 PM   #5 (permalink)
ok i bought a new
clutch
flywheel
slave cylinder
master slave cylinder and just put a gallon of tranny fluid in my 5spd. trans.
it is still grinding.
i have a pedal assembly out if a 87 toyota pickup 4cylinder in my 89 toyota v6 4runner.
any ideas what it is?
jvc971 is offline
Old 09-12-2008, 09:14 AM   #6 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
What kind of "grinding" is it? Grinding between gears, or grinding all the time?
Could be that you damaged the gears from running it with no oil.
Could be that your clutch isnt fully engaging. You need to adjust the slave cylinder rod or clutch pedal to get full travel.
Adam F is offline
Old 09-14-2008, 08:59 AM   #7 (permalink)
it is grinding when trying to go into reverse but it wont go into first with the engine on. the clutch is fully adjusted out.
jvc971 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Manual vs Auto Redeyejedi 3.4 Swaps 10 04-02-2008 02:48 PM
Manual or Auto 3.4L same? Chuki 95.5-2004 Tacomas & 96-2002 4Runners 13 07-02-2007 12:47 AM
Service Manual for 1988 3vze? MightyToy 86-95 Trucks & 4Runners 5 03-05-2006 08:19 PM
3vze AT to Manual Conversion yotamaniac 95.5-2004 Tacomas & 96-2002 4Runners 1 05-24-2005 06:03 AM
Auto To Manual lunatic14r 95.5-2004 Tacomas & 96-2002 4Runners 1 02-27-2003 07:20 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
