Sign in using an external account
| Engine Swaps Swapping an engine in your Toy, here is where to learn how |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
3T-GTE in a 4runner?
#2 (permalink) |
Personal
Sales Rating: (0)
Probably because its a 1.8L motor that makes peak torque at 4,800 rpm. Not exactly a great truck motor.
__________________
'85 Xtra Cab Sr5 w/7mgte swap: http://www.yotatech.com/f161/cant-wait-boost-egesledders-7mgte-swap-255991/ '99 GasGas 300 '09 Arctic Cat Turbo M8 '90 Honda XR 280 |
#3 (permalink) |
Personal
Sales Rating: (0)
3S-GTE 1999–2007 1,998 cc 256 bhp at 6,200 rpm 324 N·m (239 lb·ft) at 4,400 rpm found in Caldina GT-T (ST215), Caldina GT-Four (ST246)
the 22R-TE 135hp at 4,800 rpm and 173 at 2,800 rpm as a turbocharged 22re, single row timing chain what people assume is that a sports cars like the celica gt-four (4wd rally car) wouldn't want low end torque as well as just a great all round power band. The VVT-I setup broadened the power band GREATLY even though peak power on that car was at 4,400 rpm. I personally think the motor will work great if you plumb it right and dont cook the rings. With that being said there are some other motor options to think about. I have seen people put in the 1.6L and 1.9tdi turbo diesels with great success as well. If I was in your shoes I would look at what I want and had access to. If you want a lighter motor and dont care where it comes from or the gas mileage, how about a 13b rotary engine. They hit their torque band under 2k rpm and produce more as the rpms go up (seen those as daily drivers since the rotary was better on fuel then the 22re). Plus you cut the weight of the engine bay by a couple hundred pounds. In the end there is one main problem with running a performance car engine in a truck. The cams are really not cut for constant low end crawling ..... but.... depending on what your doing with it. It really shouldn't be that much of an issue Especially in 4L ps. have you thought about a bigger motor.... like a 7m-gte and making 400hp reliably with lots of torque
__________________
If you don't break something, your not trying hard enough. If you break a lot.. your probably not driving a Toyota. FUTURE UPGRADES INCLUDE LEXUS 4.0 SUPERCHARGED 1UZ-FE MOTOR ON LIQUID PROPANE DIRECT INJECTION, 4L60E AUTO WITH ATLAS 3 SPEED TRANSFERCASE SUPRALUX FRONT 8INCH DIFF AND AXLE SWAP http://toyotasurf.asn.au/forum/viewt...light=supralux |
#4 (permalink) |
Personal
Sales Rating: (0)
So the 3S is completely different than a 3T. Still not something I would want in a truck.
Also, the 7m still doesn't make a lot of low end torque like most newer truck v6's do, ask me how I know... From 3500 rpm and up though, its quite exciting.
__________________
#5 (permalink) |
Personal
Sales Rating: (0)
How about a 1gr-fe with a 6 speed manual?
__________________
#6 (permalink) | |
Personal
Sales Rating: (0)
[OP]
ive got a guy near me who cuts cams and has been for decades. he cut a backwards cam for my buddies honda so it sound run backwards and keep tracton on the front wheels. so im sure he could cut me a cam to get some more low end torque out of a 3T. this isnt a crawling truck its a daily driver that sees mud
__________________
1986 4runner SR5, 22re freshly rebuilt, engnbldr street rv head, 268/torkr cam, lce header and pro flow exhaust, 5spd, 3 inch body, 15x10 M/T classic locks, 35x12.50 Thornturds, 5.29's and detroit locker in the rear (only 2wd for now) Quote:
#7 (permalink) |
Personal
Sales Rating: (0)
W T F are you talking about?
__________________
We're sorry, theYOTATECH member you have reached is temporarily out of order or is no longer in service. Please feel free to ask our many other highly informed members about your problem. Or try using the search feature to find the appropriate information by yourself, and solve the issue on your own. Thank you for choosingYOTATECH. Good bye. I'm Cuckoo For YOTA Trucks! |
| Tags |
| 3t, 3tgte, 4runner, 81, corolla, forums, gte, hp, motor, power, rotary, whats |
