22RE Runs (Codes 3 & 7) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-11-2009, 05:54 PM   #1 (permalink)
01mudslinger's Avatar
Question 22RE Runs (Codes 3 & 7)
If some of you have been following my other thread i just rebuilt this 22R and done the EFI Swap all in one since i also put a EFI cab on my frame. Well as of this evening we finally got it cranked and running. Not real sure how, lol, we switched computers, but we had done this befoe also. Anyways its running but as soon as it cranked it went straight to 2000 Rpm's and fluctuats between 2000 and 2500. Cut it off and cranked it back several times and same thing. Pressing Gas pedel seems unresponsive some, cuts in and out. All the sensors checked out ok by the book. Anybody got and ideas on how to bring the idle back down to normal?
01mudslinger is offline
Old 06-11-2009, 06:06 PM   #2 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
By sensors, did the TPS and AFM check out? How about the wires at the computer from all the sensors?
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
THE ULTIMATE TOYOTA RESOURCE
'86 4Runner SR5 22R-E
4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear.
Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000
Current pics
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
Quote:
Originally Posted by Junkers88 View Post
Admit it, you like reading my posts. It reminds you of the days before your runner was the monster that it is now.
BigBluePile is offline
Old 06-11-2009, 07:29 PM   #3 (permalink)
yea TPS and AFM checked out good, i didnt check the wires at the ECU. What would Be a good starting point there?
Old 06-11-2009, 07:44 PM   #4 (permalink)
If all the sensors read out "good," then I would make sure the ECU is getting the right info. The fsm should be able to help to read out at the ECU. Make sure you don't have any vacuum leaks and that all that stuff is connected.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 06-11-2009, 09:54 PM   #5 (permalink)
desertcamper67's Avatar
Does your throttle return spring looks like the first pic or the second?
I just replaced my TPS to get rid of a Code 7
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front
Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks
32x11.5-15 BFG AT's
Quote:
Do I like what I have-Yes.
Does it sound good-Yes.
Does it intimidate Ricers-Oh yeah.
Does it perform-Yes.
desertcamper67 is offline
Old 06-14-2009, 04:43 PM   #6 (permalink)
Changed the TPS and got it down to 8-900RPMs and the gas pedal does respond. Drove it around the yard a little bit yesterday. One thing i noticed yesterday got me alittle curious. It has a kinda rough idle, not to awful bad. But if you cut the fuel pump off before you cut the truck off and let it run for a minute till the fuel runs out the line, as soon as you cut the pump off it smooths up nice and pretty. Thing that could be the pressure regulator or somthing?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3.4 liter Build Runs rich Codes P0120, P0171, P0505 hross14 3.4 Swaps 14 06-01-2009 07:46 AM
Chugging, hiccuping otherwise runs fine no codes? solarae 95.5-2004 Tacomas & 96-2002 4Runners 9 05-30-2008 10:54 AM
'87 22RE, starts & runs fine then dies after 10 min---2 codes rmacFJ62 86-95 Trucks & 4Runners 5 04-11-2007 04:03 PM
3VZE runs rough & misses kwoes 86-95 Trucks & 4Runners 12 11-09-2006 08:45 PM
Help Check Engine Cel codes Trans codes Brake codes NicksBlue934runner 86-95 Trucks & 4Runners 2 04-26-2006 05:35 AM
2009 InternetBrands, Inc.
