Engine Swaps Swapping an engine in your Toy, here is where to learn how
22re for a 71 Toyota Corona
Old 05-16-2013, 08:17 PM
TheGreatDraven's Avatar
Im looking to swap the current engine of this car to a 22RE and install some turbo into it. What exactly would I need and what would it run me for a decent engine and tranny?
Attached Thumbnails 22re for a 71 Toyota Corona-3ff3i13m45i85g65j5d3v683bdae870271036.jpg
Old 05-16-2013, 09:26 PM
SCToy's Avatar
If you're looking for more power than a NA 22RE, a 3RZ-FE will be a cheaper option than a turbo. Perhaps a 4AGZE?
Old 05-16-2013, 09:40 PM
totally a bro
Staff
vital22re's Avatar
buy a wrecked 2wd tacoma. search craigslist.
Old 05-16-2013, 09:48 PM
rocky279's Avatar
Nothing wrong with making your own manifold, I did. I used flat 14Ga plate layed out tge design that would fit the allotted space and then unfolded tge bends onto a flat sheet tgat I had water-jet cut. It cost me $109 for materials cut to my spec, including the flanges. The thingvassembled in an afternoon with torch to heat and bend plates, a vice, vis grips, clamps and of course a MIG welder. You can see pics in my gallery, link at the bottom of this post.
The factory ECU's are setup for a particular set of engine parameters. You are heading off the ranch on this project. I would reccomend Megasquirt or dome other programmable system. The beauty of MS, is the DIYPNP will plug into a factory harness, and you can use as many of the factory parts as you want to set this up fairly easilly.
2013 MERCEDES BENZ SL-CLASS
Old 05-16-2013, 09:55 PM
SCToy's Avatar
Even with forced induction the 22re doesn't make that much power. Its a cost to performance ratio. There are better performing engines out there for less money. If you're going to purchase the complete package, its not really a cost effective choice. If he already had a 22re in there, it would be much more viable.
Just my opinion.
Old 05-16-2013, 10:54 PM
I just want something thats going to be easier to mod/give me more performance and power rather than the stock 8RC.
Old 05-17-2013, 06:19 AM
SCToy's Avatar
Certainly, I think a 22re is a pretty decent choice if an NA one is going to satisfy you, but if you want more power than that. A turbo is going to cost you more than a 2RZ or 3RZ and will net you basically the same performance.
Old 05-17-2013, 06:21 AM
SCToy's Avatar
Like vital suggested, search craigslist for a wrecked taco and get a complete donor. That'll cost you less in the long run than sourcing all the parts.
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22re for a 71 Toyota Corona
