22r to 22re
are you looking to swap the motors or just the efi parts on the carb motor? if swapping motors youll need computer gas tank exaust manifold talilight wiring harness {contains the wiring for electric fuel pump and all of the wing in the front end of the truck motor harness headlight harness fuse box re engine and everything attatched to it
Just drag the whole truck home you will be glad you did.Plan just how your upgrading the fuel system to the EFI pressures
EFI fuel management ECU engine harness and Injectors.all the sensors
Figure out if your swapping parts or the complete engine.
Then go from there .
Hello everybody,I have a 94 toyota 4x4 22re needs a engine would a 89 22r work in my truck? the 89 22r runs good and it's affordable and what I can afford ty everybody for your input .
Staff
The 89 motor will work. You will have to remove the dish cam that drives the mechanical fuel pump and swap distributors. Add your fuel filter mount on the passenger side and all of your intake and emissions to the motor.
If using a 2wd motor, you will need to swap oil pans and pickup tubes.
chuckd83
11-30-2015 01:40 PM
roydavis
11-12-2015 07:20 AM
Brandon Mason
11-07-2015 11:47 PM
