Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
20r engine rebuild, what engine???
i am in the process of rebuilding a 1978 or 79 20r and the new piston rings that i had ordered(seperate from crank kit) were to small. they were for a 88.7mm ? piston and mine has a 93mm piston in it like in the 22r . the engine i was told came out of a 2wd pickup. i had bought the engine for $50 and run it in my trail buggy for 2 years. the oil pressure went south and spun a bearing, the engine had more pony's(seemed like to me) then the other 2 22r's i had had in it. questions is would anyone know what this engine would have come out of having the bigger 22r pistons in it. my thought might be a rv or a box truck??? any thought's.
(by the way it is stamped 20r on the block and on the head under the cam and i dont think it has been bored out)
__________________
I'm not stuck!!! It will start moving in a second just watch!!!!!! '85 toyota truck slightly modified 34-9.50-15 super swampers |
| Sponsored Links |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| I have this Engine... 20R | Woodartisan | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 01-05-2008 11:35 AM |
| Why does my 80 20R engine shake | NoLookingBack | Pre 84 Trucks | 13 | 12-13-2007 03:42 PM |
| transmission change for 20R engine | jbaa02 | Newbie Tech Section | 0 | 12-09-2007 07:21 PM |
| 22r truck engine into a 20r 77 celica body? | sampson | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 06-30-2005 04:12 PM |
| 20r engine to a 22re transmission! will it work, need help quick! | wimpywade94 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 09-17-2003 05:05 AM |
