YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-02-2008, 02:08 PM   #1 (permalink)
mudboy's Avatar
Send a message via Yahoo to mudboy
20r engine rebuild, what engine???
i am in the process of rebuilding a 1978 or 79 20r and the new piston rings that i had ordered(seperate from crank kit) were to small. they were for a 88.7mm ? piston and mine has a 93mm piston in it like in the 22r . the engine i was told came out of a 2wd pickup. i had bought the engine for $50 and run it in my trail buggy for 2 years. the oil pressure went south and spun a bearing, the engine had more pony's(seemed like to me) then the other 2 22r's i had had in it. questions is would anyone know what this engine would have come out of having the bigger 22r pistons in it. my thought might be a rv or a box truck??? any thought's.
(by the way it is stamped 20r on the block and on the head under the cam and i dont think it has been bored out)
__________________
I'm not stuck!!! It will start moving in a second just watch!!!!!!
'85 toyota truck slightly modified
34-9.50-15 super swampers
mudboy is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
I have this Engine... 20R Woodartisan 95.5-2004 Tacomas & 96-2002 4Runners 6 01-05-2008 11:35 AM
Why does my 80 20R engine shake NoLookingBack Pre 84 Trucks 13 12-13-2007 03:42 PM
transmission change for 20R engine jbaa02 Newbie Tech Section 0 12-09-2007 07:21 PM
22r truck engine into a 20r 77 celica body? sampson 95.5-2004 Tacomas & 96-2002 4Runners 2 06-30-2005 04:12 PM
20r engine to a 22re transmission! will it work, need help quick! wimpywade94 95.5-2004 Tacomas & 96-2002 4Runners 1 09-17-2003 05:05 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
