| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
1998 4.3 SPI with 4l60e swap.
#2 (permalink) |
Banned 'cause I was 4runnerchevy also banned
The oil and temp sensor are needed and will throw a code if not connected. Find a different port.
The wiring is easy and I just posted on a different thread some info. If you have the pinout for the ECU, I can tell you what to hook up. As far as the 4l60, you will need 2 adapters from Advance. The 700R4 adapter and the tailshaft adapter. It will also come with a tailshaft and that will need to be installed. Any other info just ask. |
#3 (permalink) |
I have the pinout:
1. fuel pump relay 2. 3. vss output( I think this is for the CC) 4. vss output( for the chevy speedometer) 5. MIL control ( I think I hook this to the toyota check engion light) 6. 7. 8. 9. 10. brake signal(I think this is for the CC or maybe the tranny lockup) 11. serrial data( I think this is for the OBD2 scanner) 12. 13. Ignition+ voltage 14. serial data( also for the OBD2) 15. 16. EGR valve control 17. Ignition+ voltage 18. Ignition+ voltage 19. 4wd wheel lock input 20. EGR vavle low 21. 22. CPP switch signal 23. 4wd low signal 24. Cruise engaged signal. I have the transfere case bolted to the tranny already. Also how will the alternater work with the stock wiring harness? it looks pretty simple, just hook up the wiring harness and the big wire goes to the battery+. Did you use the stock chevy fuse block for powering everything? Thanks Brent |
#4 (permalink) |
Hears a few more questions.
How did you wire up the "plug-in" for the obd2 scanner? I traced the wires and it looks like it talks to a bunch of stuff I am not using. Or do I even need this? when I have a problem, I can troubleshoot it without a scanner in If have to. Did you have any problems with the VATS ( vehical anti theft system) If I just snip off the wires and throw the box away will it throw a code? I think the VATS just makes the ecu not power up the fuel pump. I plan on powering it up another way, so If this is all it does will it be a problem? Will I have to get the ecu reflashed? I know nothing about newer computerized cars, I have done a ton of searching on different forums for this and knowone gives the same information. I would think it would drive better if it was flashed becouse of the different tire size. witch maked different shift points. I also put a shift kit in the tranny and I had to replace the crank posistion sencer. Is this going to throw it all off? Thanks Brent |
#5 (permalink) |
Can anyone else help out a little?
#6 (permalink) |
86toylet was banned. is there anyone else that can help?
I think I have came to the conclusion that I am having the ECU reflashed, to get rid of the VATS, possible the 3rd O2 sencer(the one past the cat) and maybe the EGR stuff. Has anyone else flashed out the VATS, the 3rd O2 senser or the EGR? |
| Tags |
| 1998, 43, running, temp |
