YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-18-2008, 03:21 PM   #1 (permalink)
1985 FJ60 V8 swap
I have an 85 FJ60 that is mostly stock, except for a mild lift in the back to better fit 33x12.50x15's. It has a bunch of miles on it and I am overhauling/rebuilding the suspension. Original carb 2F six cylinder, 4 speed, transfer case and running gear. I'm planning on a V8 swap for all the obvious reasons including a noisy lifter in the motor.
Motor I am planning on is any of the Gen III GM 5.3, any code (LM7/LM4/L59/L33). Fuel injection is just as easy as a carb, so that is probably the route that I will go. I want to stick with a manual trans for driveability purposes including better mpg, and an upgrade to a 5 speed.
I have read a bunch of tech stuff from Advanced Adapters on the different conversion kits they have and different routes to go. They suggest using the Dodge version of the NV4500 for strength and using their adapter to retain the stock toyota transfer case. Going this route means I don't have to replace the rear end because of the offset differential. That's where I run into problems.
The questions I have are:
1. Is there any Toyota 5 speed that will handle the 5.3's torque and bolt directly up to the original FJ60 transfer case? Model numbers and years help a lot if there is.
2. Advice from anyone else that has tried this before, what did you end up doing?
3. Anybody do a Toyota V8 swap? Did that make it any easier? If so, what motor and set up did you use?
I am trying to build on a budget so I want to do it right the first time. If anyone knows of a way to keep it as simple as possible or has experience I would appreciate input. I don't want to hack this thing up or make it a hard core off road rig, but it is my camping rig and frequently sees a combination of highway driving to an offroad situation. Thanks in advance!
FJ'd cruiser is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Clean 1985 FJ60 Land Cruiser jakesooy Vehicles - Trailers (Complete) 17 03-01-2008 03:06 PM
1985 SR5 pickup V8 swap bignigel85 Vehicles - Trailers (Complete) 8 10-14-2007 09:24 AM
1985 FJ60 Ohio, for $1250 Lance Vehicles - Trailers (Complete) 5 10-24-2006 07:42 PM
New FJ60 FilthyRich Early Land Cruisers 40 10-23-2005 10:35 PM
1985 Celica 22r - 1987 4Runner - Engine Swap Secret Squirell 95.5-2004 Tacomas & 96-2002 4Runners 26 08-18-2004 09:08 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
