YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Trip Planning, Trail Reports-Photos, Land Usage-Responsibility, 4Wheeling 101, & Expedition Gear > 4Wheeling 101
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-07-2008, 10:10 PM   #1 (permalink)
dms1's Avatar
4wd with an automatic transmission question
Hello Yotatech, I just purchased a 99 4wd 4 Runner with a V6 and had some questions pertaining to using an automatic transmission with 4wd;
1. When the transfer case is in 4wd low, should I leave the transmision in "drive" or should I \ or can I also put the transmisssion in low?
2. Is it ok to drive this model in 4wd hi on the freeway when it is raining or snowing?
3. Is there a way to disable the airbags when in 4wd and is this nesessary? The manual says the airbags are turned off when the electric locker is turned on, but I dont have an electric locker.
Thanks in advance
Dave S
P.S. I have an 85 Runner with a manual transmission, but never drove a 4wd with auto until now.
__________________
Dave S
85 4Runner
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency.
dms1 is offline
Sponsored Links
To remove this ad, register today!
Old 02-07-2008, 10:14 PM   #2 (permalink)
111db's Avatar
Send a message via MSN to 111db
1. Yes you can leave it in Drive or Low or whatever suits the conditions.
2. I wouldn't put it in 4wd in the rain, but if you have snow it will be ok. If there isn't a little slippage available, the transfercase will bind up.
3. Not necessary as far as I know. Mine are always "active"
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 02-08-2008, 06:31 AM   #3 (permalink)
tc
tc's Avatar
Putting the transmission in L will make it stay in first. When going down steep hills, this is CRITICAL, as otherwise, the transmission may sense the load and want to upshift making you lose control.
After seeing a truck fall nose first more than 30 feet and the airbags not deploy, I stopped worrying about them blowing during "normal" offroading. I think they are automatically deactivated below 25MPH anyways.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 02-08-2008, 11:26 AM   #4 (permalink)
eric-the-red's Avatar
I have an auto in my 01 4Runner, and I very seldom keep it on Drive when offroad. For gravel roads and easy trails in 4HI I'll keep the trans in 2. Anytime I'm in 4LO I usually keep the trans in L, like tc said you don't want it to shift at the wrong time.
As for the airbags the newer ones use a deceleration sensor, not impact. And they usually aren't active below 20-25 miles per hour. I think it's safer to take the very slight risk of them going off accidently than not go off when you do need them.
eric-the-red is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Automatic Transmission Sealant Question 4Runnerman 95.5-2004 Tacomas & 96-2002 4Runners 1 11-29-2006 03:52 PM
Question about 1991 Toyota Automatic Transmission White Roadster 95.5-2004 Tacomas & 96-2002 4Runners 5 09-11-2005 11:33 PM
Automatic Transmission Question YeloSub7 Maintenance & Repair Archives 7 05-04-2005 06:05 PM
Automatic Transmission Tranfer Case question Teamsobaco 95.5-2004 Tacomas & 96-2002 4Runners 12 02-19-2005 03:14 PM
Automatic Transmission Compatability Question RkyMtn_Toy 95.5-2004 Tacomas & 96-2002 4Runners 6 01-26-2004 05:07 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
