YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-26-2008, 10:35 AM   #1 (permalink)
pepsibluefloat's Avatar
Send a message via AIM to pepsibluefloat Send a message via MSN to pepsibluefloat Send a message via Yahoo to pepsibluefloat
Wheel Backspacing question..
Im doing a 3" SAS on my 4runner and its time for me to buy wheels and tires. Im going w/ 35's on 15x10 wheels. With the SAS ive got the 1.5" wheel spacers to make the front axle the same width as the rear.
what do ya'll think good backspacing would be?
__________________
1988 4runner::SAS|3vze|A340H|5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|35" Goodyear MT/R
My 4runner n stuff
pepsibluefloat is offline
Sponsored Links
To remove this ad, register today!
Old 07-26-2008, 10:50 AM   #2 (permalink)
4Crawler's Avatar
Stock is 4.75", with the spacers up front you'll be fine w/ stock backspacing and with the added wheel width, you'll already be 6" wider than stock (3" per side). So it all depends on how wide you want to end up:
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-26-2008, 10:56 AM   #3 (permalink)
awesome, so 4" backspacing should have no problem with rubbing then.
thanks for the quick reply
__________________
My 4runner n stuff
Old 07-26-2008, 11:52 AM   #4 (permalink)
4Crawler's Avatar
If your current tires and stock wheels work fine w/o rubbing, then anything with less backspacing should be fine. You can check clearances around your current tires to see if there is room for the larger tire. Measure out in radius 1/2 the difference in tire height and in/out from the tread edge 1/2 the difference in tire width to see.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Wheel backspacing? caboverpete 86-95 Trucks & 4Runners 3 06-24-2007 02:34 PM
Wheel Backspacing for 88 P/U iamspt 86-95 Trucks & 4Runners 1 04-09-2007 11:34 AM
Wheel backspacing? Stomis 86-95 Trucks & 4Runners 0 04-03-2007 07:00 PM
my lift opinion & wheel backspacing question traben27 86-95 Trucks & 4Runners 4 02-14-2007 04:37 PM
Question about wheel size and backspacing ... BogeVR6 95.5-2004 Tacomas & 96-2002 4Runners 3 07-31-2003 05:13 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
