what axel do i have..HELP! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-14-2009, 12:00 PM   #1 (permalink)
randyc's Avatar
i just recently traded my blazer for a toyota truck....my neighbor told me the front axle was off of a landcruiser,i put the motor in the truck the other day and noticed i cant use 4wheel driver b/c the front end has diffrent gears than the back.....i think the back has 411 and front has 373 i think,im going to check b4 i order gears.....but i need to knw exactly what my front end is before i can do that...so i found these numbers on it but i cant find anything about them on the internet.......(A51X)
randyc is offline
Old 05-14-2009, 12:08 PM   #2 (permalink)
89silverpu's Avatar
Location: Vacaville/Sierra Nevada Mountains, CA/ UNLV (Las Vegas), NV
Post up a picture. Host it on photobucket.com or imageshack.us if it is the original axle, and it is a solid axle, it is a toyota 8 inch. If it's independent front suspension, it's 7.5 inch. Post up the year of the truck to get more help also. If it's not the stock axle and it had a solid axle swap, my guess would be a Dana 44 most likely from a Jeep Wagoneer. Post up pics for better info. Also, no Toyota's came with 3.73 gears.
__________________
'89 Beater Jeep Eater in progress
4.88's, TRD e-locker, Dual Cases, 33's, Armored,
Tread Lightly
Mixchallenge.info
89silverpu is offline
Old 05-14-2009, 12:10 PM   #3 (permalink)
randyc's Avatar
the truck is a 85...dont think it is the factory axel tho...im charging camera now ill post some pics ASAP
randyc is offline
Old 05-14-2009, 12:20 PM   #4 (permalink)
randyc's Avatar
randyc is offline
Old 05-14-2009, 12:21 PM   #5 (permalink)
randyc's Avatar
randyc is offline
Old 05-14-2009, 01:30 PM   #6 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
Deleted your other thread.. no need to post twice
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is offline
Old 05-14-2009, 01:34 PM   #7 (permalink)
89silverpu's Avatar
That's the stock 85 axle. It should have 4.11 or 4.10 gears as well.
__________________
Tread Lightly
Mixchallenge.info
Old 05-14-2009, 01:42 PM   #8 (permalink)
89silverpu's Avatar
Quote:
Originally Posted by randyc View Post
I don't know what that yellow thing is, maybe some aftermarket tracking bar?
__________________
Tread Lightly
Mixchallenge.info
Old 05-14-2009, 01:46 PM   #9 (permalink)
Plumbrbob's Avatar
it looks like a 81-83 SFA out of a toyota the bottom truss stops before the u-joints. as far as the gearing goes I have a 3.80 8" member in my garage a lot of stuff get swapped around sometimes thats not suppose to be there.
Its possible the PO bent and broke his and threw in a MUTT of parts to get back on the road or get it put back together to sell it off to you.,
Order gears for 8" toyota 3rds
__________________
79 YotA ThinG
Mods: http://www.yotatech.com/blogs/plumbr...list-mods.html
Plumbrbob is offline
Old 05-14-2009, 02:11 PM   #10 (permalink)
4Crawler's Avatar
Quote:
That is a dropped drag link (for steering). Also looks to have a flipped ball on the steering j-arm.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-14-2009, 02:16 PM   #11 (permalink)
randyc's Avatar
yeah i knw what you mean....it does have diffrent gears in the back than the front thought...i done the driveshaft test and the back driveshaft turned just alil over 2 turns for the tire to make a one complete rotation..and the front was almost 3 turns....the truck has a 350 with a few goodys im thinking 4.88's front and back would be good...or maybe just keep the back gears and do 4.11s all the way around
randyc is offline
Old 05-14-2009, 02:17 PM   #12 (permalink)
Plumbrbob's Avatar
Quote:
yea its a z-bar or adj. drag link the old school steering correction for 4" or more lifts on SFA, x2 it looks like it got he ball flip mod too.
i think the diff i have is a 3.90 39x10 its something like that
__________________
79 YotA ThinG
Old 05-14-2009, 02:18 PM   #13 (permalink)
randyc's Avatar
about the steering it does fine with the tires off the ground but when you let the jack down it doesnt wana turn to the right good....any advice on that
randyc is offline
Old 05-14-2009, 02:23 PM   #14 (permalink)
Plumbrbob's Avatar
maybe the PO was thinking of going to 3.90 gears then since you the power to turn big tires. IMO I would drop to the 3.90 or 4.10 R&P if you have SB350, you can find complete 4.10's and 3.90's on craigslist for $30 to $50 bucks, If you break 4.88's then its 150ish for the R&P then another 150ish for set up considering you can use your old bearings,carrier,or locker.
__________________
79 YotA ThinG
Old 05-14-2009, 02:26 PM   #15 (permalink)
randyc's Avatar
yeah he could have been...truck was ment to be a mud race truck..i just wana take it out and hit a few mud holes,but yet still drive it too
randyc is offline
Old 05-14-2009, 02:28 PM   #16 (permalink)
Plumbrbob's Avatar
So there is no limitations lock to lock on a jack but when appliedon the ground with a load on the tires it wont turn to the right.
IMO it sounds like the steering box is faulty possible blown seal you shoudl be able to find a good used replacement for $20 -$50
if you like to wheel this beast i would consider a high steer mod, you will only find trouble with that old dinosuar steering setup
__________________
79 YotA ThinG
Old 05-14-2009, 02:35 PM   #17 (permalink)
randyc's Avatar
yeah it is leaking on the side were the arm drops down from the box....i would like to upgrage the steering but dont wana put alot of $ into the truck
randyc is offline
Old 05-14-2009, 02:51 PM   #18 (permalink)
Plumbrbob's Avatar
find a used replacement box then, thats the easiest way IMO! trying to figure out how to take that thing apart is a PITA, if you take it apart and the ball bearings fall out everywhere well
should be able to find one for cheap wrecking yard or CL maybe even e-bay
Soak it down with PB blaster its gonna be a fun
__________________
79 YotA ThinG
Tags
ball, drag, flip, jarm, link, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
leaky cv axel yotatrance Newbie Tech Section 1 05-07-2009 02:19 PM
which axel??????? ryanflknr Newbie Tech Section 13 03-04-2008 12:11 PM
Axel swap natural50cal Offroad Tech 5 10-18-2007 09:28 AM
axel ? killa b 86-95 Trucks & 4Runners 8 09-26-2007 05:05 PM
Will Tacoma axel graybeard 95.5-2004 Tacomas & 96-2002 4Runners 2 02-11-2004 02:52 PM
2009 InternetBrands, Inc.
