Try and Keep 4link or do leaf swap?? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-11-2007, 09:02 AM   #1 (permalink)
4Runner92sr5's Avatar
Send a message via AIM to 4Runner92sr5
as titled im in a debate whether or not to do a leaf swap in the rear or buy the all pro lower and upper links. I know i can fabricate extensions on the axle to make the upper link angle a lot less severe so it won't hit the gas tank. But its gonna be about the same amount to do either of them. What are the pros and cons of this am i going to lose stability on road with all leaves and what are the differences offroad from coil in the rear to leaf in the rear?? thanks ahead of time.
__________________
"doing a body lift is like sleeping with a blow up doll, it might make you feel better for now, but it just doesn't feel right in the morning"
1992 4Runner Auto 3.0 135K SASed
Free Flow (no cat) Flowmaster 40 exhaust
33x12.5 BFG Mud Terrains
Marlin Crawler Rear Bumper
All Pro Front Bumper
1984 Front Axle
TG SAS kit 4'' w/ bilstein 5150's
OME 863 coils
ProComp 4" Panhard drop bracket
My SAS Thread http://www.yotatech.com/f152/startin...ss-sas-118997/
4Runner92sr5 is offline
Old 08-11-2007, 09:17 AM   #2 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
I'm not an expert but I've decide to go leaves in all corners when I do my SAS.
I think leaves are easier, and will be simillar manners to the front, I have the impression than having coils in the rear and leaves in the front would make my truck more tippy when offroading. Also, if you buy the upper and lower links you're almost spending what a leaves kit cost...
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write...
Blizzard is offline
Old 08-11-2007, 10:47 AM   #3 (permalink)
yeah thats exactly what i was thinking i think ill be savin my nickels and dimes for the rear leaf swap hahaha
__________________
1984 Front Axle
OME 863 coils
Old 08-13-2007, 12:20 PM   #4 (permalink)
When I do my SAS I will be putting in 63" chev leafs, to upgrade the coil set up will cost me 3x as much.
Jeremy
Wheelingnoob is offline
Old 08-13-2007, 07:09 PM   #5 (permalink)
no it won't be 3x as much cuz the all pro links are 500 for all 4 and that takes care of MOST of the problem then im fabricating extenders for my upper link mounts on my axle to make the angle almost parallel with the ground and that takes care of it for around the same as the leaf swap.
__________________
1984 Front Axle
OME 863 coils
Old 08-13-2007, 11:25 PM   #6 (permalink)
Elvota's Avatar
Quote:
Didn't you forget about the price of your springs? Assuming you are going to try and gain more travel with long travel coil overs or similiar. I think links will cost more in the long run, but if done right they are probably well worth it if you plan is to really hit some aggressive trails.
But then again, what are your thoughts as to where to stuff such long springs under the back of your 4Runner? You might find that overall wheel travel is similiar between leafs and coils on a 4Runner unless you are prepared to move the coils through the bed. Links have other benefits as well though, so I can see why you are looking into them.
I wouldn't mind trying to link mine one day, but you have to be pretty much spot on with the geometry to get the ride characteristics and handling to work well. Leaves are hard to mess up. I'd be interested to learn how you are getting around some of the link complications on your 4Runner... should you go that route.
User "Flygtenstein" has a rear linked 2nd Gen if you are still looking for design ideas.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
visit the sticki chronicles
Elvota is offline
Old 08-13-2007, 11:38 PM   #7 (permalink)
Marc P's Avatar
I have kept my stock configuration for now.....but..
I have the All-Pro upper links, adjustable panhard bar, panhard drop bracket, high angle driveline, OME 860's, and adjustable Procomp shocks..
Everything I have in the back was bought used or free. If I was starting from scratch I would probably go with leaves.
__________________
1995 4Runner---SAS with goodies
Marc P is offline
Old 08-14-2007, 09:52 AM   #8 (permalink)
yeah i keep lookin at my 4link and its just too much of a hassle to try to get it right when i can just do a leaf swap and be done with it...Ill be doing a 5" leaf swap and while im back there ill do a rear disc brake conversion as well..
__________________
1984 Front Axle
OME 863 coils
Old 08-18-2007, 09:08 AM   #9 (permalink)
hey all im looking at the rear leaf swap kit and it doesn't have upper shock mounts just wondering where and how everybody mounted their shocks thanks for the help pictures would be ideal...
__________________
1984 Front Axle
OME 863 coils
Old 08-18-2007, 01:41 PM   #10 (permalink)
Elvota's Avatar
I got a hanger kit from Sky Manufacturing originally. Runs $60 and welds between the rear frame rails.
However, the shocks sit like this / \ which seems to reduce their performance. I just finished making my own cross bar to allow my shocks to sit like this ||.
Was cheaper and really made a difference with body roll and general axle control.
__________________
Elvota is offline
Old 08-18-2007, 06:25 PM   #11 (permalink)
4RunnerKid's Avatar
Send a message via AIM to 4RunnerKid Send a message via MSN to 4RunnerKid Send a message via Yahoo to 4RunnerKid
mine are | | also: http://www.yotatech.com/50535160-post133.html
__________________
-Mikey-
1993 4Runner ~ TG HD/RUF front | All Pro rear | 37" Krawlers | Marlin UM06s | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | 4xInnovations cage | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | LED rock lights | PIAA superwhites | stereo
Polygoats 4-Wheel Drive Club
Poly Performance
4RunnerKid is offline
Old 08-19-2007, 02:25 AM   #12 (permalink)
Blizzard's Avatar
Mike, did you custom made that upper supports?
David
__________________
Blizzard is offline
Old 08-19-2007, 10:33 AM   #13 (permalink)
4RunnerKid's Avatar
yeah, fabbed them up myself
__________________
-Mikey-
Poly Performance
Old 08-23-2007, 08:49 AM   #14 (permalink)
AlphaOffRoad's Avatar
The link/leaf debate comes down to a few things IMO.
-Budget - leafs will be much less, figure 2X [min.] for coils/coilovers
-Fabrication skills - Can you weld? Like fabricating? Again, coils will be more work
-Performance - Links will flex better, period. But they are less stable in some situations, and are not as predicatable as leafs...
AOR is going to be looking at building a Ftoy in the next year, and even if I had the choice to link it, I would still keep leafs. Just my $.03
__________________
-WILL@AlphaOffroad
www.ALPHAOFFROAD.COM
(307)-630-0856
Alpha OffRoad Inc. - 'The Dominant Source for Hardcore Off-Road Parts' www.ALPHAOFFROAD.com
AlphaOffRoad is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
A different kind of leaf swap question 91 4Runner 86-95 Trucks & 4Runners 5 10-10-2006 07:28 AM
chevy leaf swap? hirsche23 86-95 Trucks & 4Runners 3 04-30-2006 11:53 PM
Leaf spring swap... pretaco 95.5-2004 Tacomas & 96-2002 4Runners 2 08-22-2005 07:22 PM
which leaf springs to swap? fryeguy1983 Offroad Tech 5 01-08-2005 03:22 PM
4runner rear leaf swap AH64ID The Fab Shop 18 04-08-2004 08:28 PM
2009 InternetBrands, Inc.
