YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-18-2008, 08:25 AM   #1 (permalink)
89dlx's Avatar
Question shackle angle with no weight?
I've read that with the V6 you need to mount the front hanger forward ¾" to aid in shackle angle. I have no weight on my frame (engine/transmission is out, and the cab will be off soon). Should I tack weld the brackets, then after the truck is put together, weld everything? Right now I have a bare frame and wanted to get all the welding done at one time.
89dlx is offline
Sponsored Links
To remove this ad, register today!
Old 07-22-2008, 07:27 PM   #2 (permalink)
4rnnr33's Avatar
if you have a v6 i would definately put the hanger 3/4 forward from the frame. here is what my shackle angle looks like on my 4runner with the hanger 3/4 forward after about a weeks worth of driving so it should still settle some
__________________
95 4runner, 5 in tg sas and rear leaf swap, chopped, mx6 reservoir shocks, 35x13.50x15 toyo mt's, all pro front bumper, mile marker se9500c, rear tube bumper, hella 500's, rock lights, optima red top, glass fenders, tg 5.29's, lockright rear, detroit hp front
4rnnr33 is offline
Old 07-23-2008, 02:52 AM   #3 (permalink)
89dlx's Avatar
Thanks. Have you noticed if the shackle contacts the body mount at all?
89dlx is offline
Old 07-23-2008, 04:23 AM   #4 (permalink)
dirtoyboy's Avatar
Quote:
Touching the body mounts is not always a bad thing......some prefer the lazier angle for ride quality
You can always just trim the mounts or run banana shackles
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
I'm the yota junk man......PM me for ALL your parts needs NEW or USED
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 07-23-2008, 05:18 PM   #5 (permalink)
4rnnr33's Avatar
ya my shackles contact the body mounts just barely but ill be trimming those pretty soon
__________________
4rnnr33 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
How much CV angle is too much? n16ht5 86-95 Trucks & 4Runners 17 04-14-2008 10:19 PM
CV Angle Osep 03+ 4Runner/GX470, & 05+ Tacomas 7 12-25-2007 04:58 AM
Pinion angle + Shackle angle Island_Yota Pre 84 Trucks 1 07-27-2007 11:27 PM
SAS with buggy spring shacle mount? and steering question. meswoleshane 86-95 Trucks & 4Runners 3 01-06-2007 01:35 PM
knuckle angle ? bigamigo 95.5-2004 Tacomas & 96-2002 4Runners 8 12-28-2004 03:47 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
