SAS Tundra
Its been a while since I have been on here last, but about a month and a half ago I fell into a deep hole while crossing back over a creek and blew the motor. Replaced it myself and all is good now. But what a pain in the ass that was.
BEFORE:
AFTER:
#25
Well I decided (for now at least) to just re-do what I had to begin with in the rear. I flipped the shackle in the rear with ruffstuff shackle mounts and home made 4" shackles. I ended up taking 2 leafs out of the springs. It is a lot smoother now and has a few more inches of uptravel. The only things that I need to address now are longer shackles (5" or 6") and move the pinion angle down, either with shims or just wait and get new spring perches and ubolts so i can flip the u bolts all in one shot.
When I took out the old springs, the centering pin on the passenger side had sheared off and was bent....
shackle mounts I made for the frame...
#26
A few new updates...
#27
#29
hey man i am looking to do this swap my self could you give me some information on it. where did you find your information on this swap, what type of axles are you using and what did they come out of, what kinda springs are you using, where did you get all the other suspension parts from if you could tell me any information on this swap it would be really helpful thanks for the info man
FS[MidAtl]: 2000 Tundra (Parting out) Pennsylvania
ToyotaMD
11-09-2015 11:53 AM
LCE_Performance
10-01-2015 01:03 PM
4runnerFireman
09-29-2015 06:24 AM
